What's the best way to a replace the floor in LQ?
Last activity 2015-07-14 8:23 AM
3 replies, 5395 views
acy
Reg. Oct 2006
Posted 2015-07-12 5:03 PM (#164022)
Subject: What's the best way to a replace the floor in LQ?
I'm considering buying another trailer- haven't seen it in person yet. The seller said the roof leaked down the shower wall and onto the floor. They've resealed the roof, removed the shower and water heater, torn up all the old flooring and now it's ready for a new floor. What's the best thing to put down? I'm thinking plywood with vinyl on top? any tricks or little details I need to know? Thanks!
Posted 2015-07-13 11:12 PM (#164042 - in reply to #164022)
Subject: RE: What's the best way to a replace the floor in LQ?
Was the base subflooring affected?...also is that aluminum or wood?
acy
Reg. Oct 2006
Posted 2015-07-14 5:35 AM (#164045 - in reply to #164022)
It's a Hart trailer.    the floor has been stripped down to the aluminum.
Posted 2015-07-14 8:23 AM (#164046 - in reply to #164022)
You could apply sleepers, insulation and plywood to create a flooring, upon which any finishing could be applied. It's somewhat labour intensive, but works well. There is a product called DRIcore, that comes in 2' x 2' interlocking panels. It is made just for that purpose, and is only 3/4" thick. Once quickly installed, any type of finish flooring can be fitted; vinyl, laminate or wood. Not only does it provide a subflooring surface, but insulates and prevents moisture from attacking the interior surface. Home Depot and other lumber yards commonly sell the product.
