Batteries not charging
Last activity 2015-06-13 6:50 AM
12 replies, 7476 views
brokenboot
Posted 2015-06-11 5:08 AM (#163725)
Subject: Batteries not charging
I put two new batteries in my living quarters trailer last fall.  Yesterday when I hooked up the trailer, I used the electric jack and all was good.  I'd also used the lights inside the trailer so knew the batteries were charged.  I towed about 600 miles round trip and when I got home there was no power to unhook the trailer with the electric jack.  Everything inside the trailer was dead ... no lights, no water ... nothing.  It's almost as though being hooked up to the truck drained the batteries.  Is that possible?  All running lights and brakes still worked.  I've checked fuses and everything looks good.  I'm puzzled.  Has anyone had similar experiences or have any ideas what might cause this?  Thank you.
- Greg
kooner
Reg. Jun 2011
Posted 2015-06-11 6:11 AM (#163727 - in reply to #163725)
Subject: RE: Batteries not charging
same thing happened to me a while back and it was the main ground wire on the battery's.once I cleaned the cable connection to the trailer frame all is well.
brokenboot
Posted 2015-06-11 7:34 AM (#163729 - in reply to #163725)
Thank you, I'll give that a try.
Posted 2015-06-11 7:39 AM (#163730 - in reply to #163725)
If the batteries' cable connections are clean and secure, check the fuses/breakers powering your converter. You may have inadvertently caused a polarity or ground issue when the batteries were initially installed. The trailer's running lights and brakes are powered from your truck, not the LQ batteries.
lmassom
Reg. Jul 2014
Posted 2015-06-11 8:26 AM (#163731 - in reply to #163725)
Batteries should charge while towing. This of course depends on several factors, such as wiring and you tow vehicle. You may have a blown fuse on the tow vehicle.
brokenboot
Posted 2015-06-11 9:16 AM (#163738 - in reply to #163725)
I checked those breakers/fuses in the trailer.  However, I did not consider the fuse in my truck.  Would the running lights and brakes still work if the fuse in my truck was blown?
Thanks for the suggestions on what to look for.  I do believe I'll get this resolved so we can take our next trip without worrying about having power once we get there.
Posted 2015-06-11 5:36 PM (#163750 - in reply to #163738)
Originally written by brokenboot on 2015-06-11 9:16 AM
Depends on the truck...A GM Duramax has STUD #2 fuse for trailer power and separate fuses for all the other trailer functions https://www.google.com/search?q=GM+duramax+fuse+box&client=safari&sa...
Posted 2015-06-11 5:37 PM (#163751 - in reply to #163725)
http://www.gmtruckclub.com/forum/data/photos/l/24/24528-1420942576-...
beeoerdog
Reg. Jan 2014
Posted 2015-06-11 6:50 PM (#163752 - in reply to #163725)
Subject: charging
10010010010025
Your truck would not suck the juice out of your trailer batteries. Clean all the connections at the battery as well as ground connection
lmassom
Reg. Jul 2014
Posted 2015-06-11 7:35 PM (#163754 - in reply to #163738)
My truck (Sierra 3500) has a separate fuse for the 12 volt power to the trailer. This is separate from the running, brakes, and turn lights. This is what would charge the trailer battery while connected. Some trucks have way to prevent draining the its battery if the engine isn't running.
brokenboot
Posted 2015-06-11 8:24 PM (#163756 - in reply to #163725)
I found some corrosion where the ground wire connects to the trailer.  I took all wires off, cleaned them good and reconnected.  I could not find any bad fuses in the trailer or the truck, so I'm hoping it was the poor ground connection.  Thank you to all who responded.  You are the reason this forum is so helpful.
- Greg
Posted 2015-06-12 8:17 AM (#163761 - in reply to #163756)
Have you checked the power through the trailer's battery master switch? Do you have 12V to it ?
Shari
Posted 2015-06-13 6:50 AM (#163765 - in reply to #163725)
Happened to us as well. We were told to leave the power switch inside the trailer pulled out so it's on while charging. So I make sure I pull it out when traveling so it will charge. Haven't had it happen again.
