Brake Controller not detecting trailer
Last activity 2015-05-30 9:53 PM
4 replies, 7687 views
humnbass
Reg. Feb 2011
Posted 2015-05-29 8:32 PM (#163582)
Subject: Brake Controller not detecting trailer
I pull a 2 horse bumper pull trailer with my 2006 suburban with the factory tow package using a 7 pin plug. I just installed a new brake controller with the factory wiring harness that plugs in by the driver's side kick panel. The brake controller is not recognizing when the trailer is connected. There is an electric brake signal going to the tow vehicles plug. when I ground a test light to the tow vehicle and place the test light prong on the tab in the plug that carries the signal the brake controller displays as if it's connected to a trailer. When I plug the trailer to the tow vehicle the brake controller does not detect it and only displays a dot on the display. All of the lights work on the trailer as they should. Any assistance would be highly appreciated as I am at my wits end.thanks.
Posted 2015-05-30 12:08 AM (#163587 - in reply to #163582)
Subject: RE: Brake Controller not detecting trailer
What kind of controller?
humnbass
Reg. Feb 2011
Posted 2015-05-30 4:31 AM (#163589 - in reply to #163582)
A pilot 2 to 6 electric brake time delayed brake controller.
skippyvcu
Reg. May 2006
Posted 2015-05-30 12:19 PM (#163597 - in reply to #163582)
Check the ground to the trailer and wiring to the trailer brakes (at the axle). For the controller to detect the trailer, some controllers check for the completed brake circuit. A broken wire, bad ground or corroded connection will sometimes cause a problem.
Posted 2015-05-30 9:53 PM (#163604 - in reply to #163582)
Originally written by humnbass on 2015-05-29 8:32 PM
http://www.etrailer.com/question-25473.html
