The things you discover
Last activity 2015-04-24 7:21 AM
11 replies, 5969 views
Linda Y
Reg. May 2007
Posted 2015-04-22 6:32 AM (#163215)
Subject: The things you discover
10010010025
So, a friend and I were searching out the source of a leak in her LQ. We found a skin panel that pulled out when the electric plug was pulled. We got to looking at it, and we could pull the entire panel away from the side of the trailer, so we looked underneath to see why it was loose. Imagine our surprise when we found that the white skin panels are held on with nothing but double stick tape and the silicone used to seal it!!!
Is that a common installation technique? We gorilla glued it back down and she resealed the entire trailer with a roofing compound sealant silicone.
This isn't a cheap cheesy trailer...it is a Dream Coach.
justgurn
Reg. Oct 2010
Posted 2015-04-22 7:41 AM (#163216 - in reply to #163215)
Subject: RE: The things you discover
3M VHB tape is very common to assemble side panels without screws or rivets. If the surfaces are prepared properly you can remove the panel without destroying it.
Posted 2015-04-22 7:57 AM (#163218 - in reply to #163215)
Have you looked at the skin on an aircraft lately!!?
diggerdoo
Reg. Oct 2009
Posted 2015-04-22 9:33 AM (#163227 - in reply to #163215)
I don't like to look at anything too closely at aircraft that I'm on or I would probably get off.
Posted 2015-04-22 8:44 PM (#163234 - in reply to #163215)
The skins of commercial aircraft are not affixed with two way tape. In fact, hundreds of thousands of rivets are utilised during the AC construction.
Linda Y
Reg. May 2007
Posted 2015-04-23 5:42 AM (#163235 - in reply to #163215)
10010010025
Is it common to apply the 3M tape, even if the panel is not held on in another way? Like putting the edges behind the extruded skin? I mean nothing was holding this on but the tape.
justgurn
Reg. Oct 2010
Posted 2015-04-23 8:33 AM (#163237 - in reply to #163235)
My Sterling Coach is all 3M VHB no rivets or screws.
RustyScupper
Reg. Mar 2013
Posted 2015-04-23 9:03 AM (#163238 - in reply to #163215)
3M VHB (VHB = Very High Bond) is very strong. Depending on the composition of the materials taped together if you tried to pull them apart you would De-laminate the material before it would let go from the tape bond.
There are knockoff brands that do not perform as well as 3M VHB. This could be the case in your instance or the surfaces were not cleaned.
postlewaitee
Reg. Jul 2014
Posted 2015-04-23 1:46 PM (#163241 - in reply to #163215)
I have the 3M tape holding on my aluminum sheet, the place i got my trailer from said they also use the recommended 3M adhesion promoter for an even better hold.
Also if the aluminum isn't cleaned properly it could compromise the effectiveness of the products used to hold the sheet on.
Posted 2015-04-23 9:17 PM (#163243 - in reply to #163215)
1000500100100100252525
wow I would think that it would be more on there to hold it together
Linda Y
Reg. May 2007
Posted 2015-04-24 6:08 AM (#163248 - in reply to #163215)
10010010025
Does anyone know what the life expectancy of the product is?
Spin Doctor
Reg. Nov 2008
Posted 2015-04-24 7:21 AM (#163249 - in reply to #163215)
When we had the front 1/2 of our Cimarron reskinned, it was amazing to me the force it took to get the sheets to come off the frames. The tape made me a believer. They used everything from all sorts of clamps, vise grips, hydraulics, release chemicals, etc but still struggled.
