2005 dodge one ton straight wire?
Last activity 2015-03-27 3:58 PM
7 replies, 4369 views
dwf1980
Reg. Mar 2015
Posted 2015-03-27 9:50 AM (#163015)
Subject: 2005 dodge one ton straight wire?
my straight wire to my 7 Prong round light plug isn't working.any ideas. I'm clueless. Thanks in advance.
beeoerdog
Reg. Jan 2014
Posted 2015-03-27 10:00 AM (#163016 - in reply to #163015)
Subject: RE: 2005 dodge one ton straight wire?
10010010010025
Start off by reading the "trailer wiring" section at the bottom of the home page....then you will be able to communicate your problem a little more clearly
dwf1980
Reg. Mar 2015
Posted 2015-03-27 10:08 AM (#163017 - in reply to #163015)
The auxilary prong that has constant power isn't working.. it is suppose to have constant power and works my spot lights exc
dwf1980
Reg. Mar 2015
Posted 2015-03-27 10:11 AM (#163018 - in reply to #163015)
beeoerdog
Reg. Jan 2014
Posted 2015-03-27 11:36 AM (#163019 - in reply to #163015)
10010010010025
check the fuses in the truck....Has this plug ever worked properly? new trailer, new truck, new plugs? Check for 12v at truck receptacle...if no voltage, then it is a loose wire or probably a blown fuse.
Posted 2015-03-27 12:18 PM (#163020 - in reply to #163019)
Not sure about the Dodge trucks but GM trucks have a big 40 amp fuse under the hood in a fuse box that sends power to that "hot all the time" center wire.
Posted 2015-03-27 3:55 PM (#163023 - in reply to #163019)
Originally written by beeoerdog on 2015-03-27 11:36 AM
What he said......do you know how to check continuity?
Posted 2015-03-27 3:58 PM (#163024 - in reply to #163015)
dwf1980...do you know how to check continuity?(I hate the fact that you can't edit posts...)
