Unusual aluminum trailer floor problem
Last activity 2015-03-23 6:35 AM
8 replies, 5821 views
jqb
Reg. Jun 2013
Posted 2015-03-20 1:19 PM (#162916)
Subject: Unusual aluminum trailer floor problem
Hello all;
I have an unusual problem that I'm having a hard time finding out what happened and how to correct it. I purchased a 2002 Silver Star trailer in very good condition, the floor had very few spots of corrosion, no holes to patch. We acid washed the floor, then applied 2 coats of Duplicolor. I wash the trailer after every use, but did not pull the mats until several months after applying the Duplicolor. I've attached photos, but it looks like a lot of corrosive spots coming thru the Duplicolor finish! When I called Duplicolor company, they suggested scrubbing with Simple Green, and then perhaps another coat of Duplicolor. Which sounds like covering the problem! The Duplicolor is adhering very well to the floor in all areas except on spot at the rear where it looks as if a hind hoof scraped it off. When I scratch at the "spots" it does not wipe clean, nor is the Duplicolor able to scratch off. Does anyone know what this is? Do I need to take it off? If so, how?
Thanks so much for your help!
(photo 2-30 then 50.jpg)
(photo 4-25 of 50.jpg)
Attachments photo 2-30 then 50.jpg (78KB - 250 downloads)
Attachments photo 4-25 of 50.jpg (73KB - 211 downloads)
kooner
Reg. Jun 2011
Posted 2015-03-20 1:51 PM (#162917 - in reply to #162916)
Subject: RE: Unusual aluminum trailer floor problem
will the white spots wash off?? almost looks to me like alkaline water spots.
jqb
Reg. Jun 2013
Posted 2015-03-20 1:55 PM (#162918 - in reply to #162917)
No, they will not wash off, looks the same after scrubbing with Simple Green.
kooner
Reg. Jun 2011
Posted 2015-03-20 2:11 PM (#162919 - in reply to #162916)
try washing a small area with vinegar and water mix, have you scraped off any of it to see what is going on under the duplicolor??
jqb
Reg. Jun 2013
Posted 2015-03-20 2:15 PM (#162920 - in reply to #162919)
The Duplicolor is adhering well, it will not scrape unless I use a screwdriver. I hoped someone would know something before I tried to scrape a section. I'll try the vinegar this weekend.
I don't mind applying another coat of Duplicolor, but don't want to cover up damage.
I'll try the vinegar!
Posted 2015-03-20 4:15 PM (#162921 - in reply to #162916)
It may be oxidation residue that was left on the back side of the mats that transferred onto the Duplicolor....
jqb
Reg. Jun 2013
Posted 2015-03-20 8:43 PM (#162923 - in reply to #162921)
If it is residue, wouldn't it wash off? I'll take a look at them deride of the mats tomorrow! Thanks for the suggestion!
Posted 2015-03-20 10:12 PM (#162924 - in reply to #162916)
Try applying some muriatic acid to a small area, and strongly agitate it as you originally did on the aluminum. Flush generously with water after the reaction has settled. Were the mats dry after they were washed and reinstalled? Did any of this material transfer to the underside of the mats? It appears that the Duplicolor is mechanically protecting the flooring, but the wetness trapped between the mats and Duplicolor, are producing some kind of reaction or oxidation. Was the original acid washing completely flushed and dried before the Duplicolor was installed? This IS an unusual outcome.
diggerdoo
Reg. Oct 2009
Posted 2015-03-23 6:35 AM (#162948 - in reply to #162916)
This looks like mine, but the duplicolor is actually popped off where those white spots are.
