Insulate the horse area?
Last activity 2015-02-18 3:32 PM
5 replies, 7452 views
Tankerbell
Reg. Nov 2009
Posted 2015-02-15 9:54 AM (#162574)
Subject: Insulate the horse area?
I have a 2009 Sundowner 2H GN. I'm thinking of insulating the horse area. Does anyone have any experience or advice? Pros? Cons? Materials? Methods?
justgurn
Reg. Oct 2010
Posted 2015-02-16 6:52 AM (#162584 - in reply to #162574)
Subject: RE: Insulate the horse area?
I would recommend insulating. I insulated my Titan steel trailer and reduced the inside temperature by 8 degrees F. I used 3M 77 spray adhesive and aluminum bubble aluminum insulation from Lowes. I cut strips of insulation to go between the roof bowes and sprayed adhesive on the roof and insulation. It never came loose.
walkin
Posted 2015-02-16 9:06 AM (#162587 - in reply to #162574)
500100
jim bob
Reg. Jan 2008
Posted 2015-02-17 7:51 AM (#162606 - in reply to #162574)
Insulating the aluminum roof in the horse area will definitely keep the trailer much cooler in the summer, and will keep the roof from dripping in cooler (fall and winter) weather. Foam board is the most used type of insulation, as you can purchase it in the same thickness that your roof bows measure. We have taken trailers on trade that the owner used foam board and silver tape to hold it to the roof bows. The silver bonding tape must be good stuff, because some of it had been there quite a while, and hadn't let loose. Good luck on your project.
postlewaitee
Reg. Jul 2014
Posted 2015-02-17 8:44 AM (#162607 - in reply to #162574)
I would recommend the foam board as insulation. I also recommend putting aluminum sheet over the foam board once you but it up (looks nicer), that's what I would do anyways.
Tankerbell
Reg. Nov 2009
Posted 2015-02-18 3:32 PM (#162617 - in reply to #162574)
Thank you so much. IF it EVER warms up.... I'll get started!!
