Not fully enclosed tack room - tack get dirty?
Last activity 2015-01-22 8:47 AM
3 replies, 4858 views
greyghost
Reg. Jan 2013
Posted 2015-01-22 7:26 AM (#162335)
Subject: Not fully enclosed tack room - tack get dirty?
Hi all, I'm looking at a 2H 2000 Morgan with tack room. It's like an open stock trailer that is converted into a 2H slant -- and the tack room is not totally enclosed -- it has a small opening (I'd say 4 inches) from the ceiling, so that the tack wall can be removed to make it an open stock. I'm wondering if anyone has experience with this -- if that opening is going to cause dirt, etc to be flung all over my tack room. A fully enclosed tack is about $1200 more -- and rather not spend the $. Or was just going to alter it somehow on my own if needed.Appreciate any input.
(inside w divider closed.jpg)
Attachments inside w divider closed.jpg (10KB - 133 downloads)
Posted 2015-01-22 7:35 AM (#162336 - in reply to #162335)
Subject: RE: Not fully enclosed tack room - tack get dirty?
That wall is to keep large critters out of there, dust, dirt, some water droplets, mice, raccoons, sparrows, etc will migrate into this tack area..... Oh, forgot to mention the snake population would like to nap in there!!!!
Posted 2015-01-22 7:52 AM (#162337 - in reply to #162335)
It would be an easy and inexpensive process, to install a plywood panel cut to fit the opening. It can then be painted to match the present interior colour. Make a cardboard template and scribe it onto the plywood. Add a few inches of height to the bottom, allowing an area to be bolted to the wall. We had a stock/combo trailer with a similar opening above the moveable bulkhead. We never closed it in and had no problems with anything being thrown into the tack area. The area did get dusty from the show grounds we frequented, but equally, so did everything else.
Spin Doctor
Reg. Nov 2008
Posted 2015-01-22 8:47 AM (#162338 - in reply to #162335)
We put a piece of "draft stop" flexible rubber on ours. It is used on overhead roll up shop doors. Is about 4" wide and is shaped like an "L". Screwed the lower part of the "L" on to the tack wall. Comes in lengths of ~12' or so. Really flexible, fairly heavey and holds up really well. Most home improvement stores care it.
Good luck!
