Trailer Hitches - Pros & Cons
Last activity 2014-12-10 6:43 PM
4 replies, 5061 views
hannahm
Reg. Sep 2014
Posted 2014-12-10 12:58 PM (#162006)
Subject: Trailer Hitches - Pros & Cons
Pros and cons to turn-over gooseneck balls (Mumby hitches in particular, which isn't a turn over since the ball comes out and a plug goes in when not in use, but same idea) vs. rails with gooseneck and 5th wheel attachments (Reese, B&W, etc)Trying to decide what to put in our new truck, thanks in advance!
Posted 2014-12-10 1:49 PM (#162007 - in reply to #162006)
Subject: RE: Trailer Hitches - Pros & Cons
Well, do you use the bed of your truck for transporting sheets of plywood or drywall?...if so, then get a removable or reversible ball...:)
Posted 2014-12-10 4:03 PM (#162011 - in reply to #162006)
Interesting that the Mumby only requires a 3 inch hole. B+W requires a 4 inch hole in the truck bed. Mumby does require drilling of the truck frame, B+W does not. (I prefer no frame drilling)Both B+W or Mumby require you grab a greasy ball to flip/remove to get a flush bed floor.I've had a B+W since 2001 and have been well pleased with it.
jmey1820
Reg. Aug 2009
Posted 2014-12-10 5:29 PM (#162012 - in reply to #162006)
We had always had Reese hitches. Always been reliable and have never had any problems.
PDGx
Reg. Jul 2011
Posted 2014-12-10 6:43 PM (#162013 - in reply to #162006)
I definitely recommend the B&W. On our third truck with a B&W with no problems. The biggest advantage to us has been the interchangeability of hitches they can handle. We have 2 ball Goosenecks, one 5th wheel, and one inverted 5th wheel. The B&W receiver accepts all of them, as well as leaving a flat bed floor when needed. Also since they don't require drilling the frame, install is pretty simple. The 4" vs 3" is probably due to the variety of hitch types it can handle. After drilling it with a hole saw, it really doesn't make any difference to the truck bed as it is either filled with a hitch, or a flipped ball. And the tongue rating is pretty high for the B&W.
