stock trailer slats
Last activity 2014-12-12 5:46 AM
8 replies, 7530 views
SpottedTApps
Reg. Oct 2009
Posted 2014-12-09 6:48 AM (#161981)
Subject: stock trailer slats
I searched prior posts, but couldn't come up with an answer.
I have a stock combo and am wanting to use it for storage, so want to fill in the slats.  It is set up to slide in something of 3/16th thickness.  I'm not worried about light, but am concerned about price and don't want wood for rotting purposes.  What does everyone use that is cost effective and easy to cut/install?
horsey1
Reg. Dec 2004
Posted 2014-12-09 7:03 AM (#161982 - in reply to #161981)
Subject: RE: stock trailer slats
Lexan. Cut it with a table saw, fine blade. Can get many shades and colors from glass shops.
CTRider
Reg. Sep 2009
Posted 2014-12-09 7:59 AM (#161985 - in reply to #161981)
10010010025
Plexiglass. You can get it at lumber/home builders shops like Home Depot, McCoys, Lowe's, etc. Cut with a jigsaw. I also think they make a special cutting tool for it. It is light, fairly cheap, and lasts.
postlewaitee
Reg. Jul 2014
Posted 2014-12-09 8:03 AM (#161986 - in reply to #161981)
Lexan is the way to go, and if its already got the track for it even better! lexan is about $80 for a sheet give or take a few bucks, and they are generally 8x4 so you can measure and see how much you will need.
Posted 2014-12-09 9:30 AM (#161991 - in reply to #161981)
A 4'x 8' piece of 3/16" polycarbonate (Lexan) or acrylic (Plexiglass) at last glance, usually costs ~ $175- $200 a sheet, plus delivery. Poly sheets are ~250X the strength of glass, while acrylics are ~10X stronger. Both are easily cut with wood working tools; table saw, jig saw etc. When cutting acrylic products, be careful not to bind the blade, as it can crack the sheet. The poly is almost indestructible and you will have little or no issues in machining your pieces. The better product to used for long term durability is the polycarbonate.
Posted 2014-12-09 11:15 AM (#161992 - in reply to #161981)
http://www.farmtek.com/farm/supplies/ProductDisplay?catalogId=15052...
Posted 2014-12-09 1:25 PM (#161993 - in reply to #161981)
Paul........That would also be an excellent material for stall ceilings and upper sidewall panels.
Posted 2014-12-11 11:22 PM (#162037 - in reply to #161981)
1000500100100100252525
I use plexiglass
RustyScupper
Reg. Mar 2013
Posted 2014-12-12 5:46 AM (#162039 - in reply to #161981)
Acrylic (plexiglass) or Lexan (Polycarbonate) are good choices. As others have stated the Lexan (polycarbonate) is stronger. Neither option is "inexpensive."
An alternative would be Expanded PVC (Sintra, Komatex, etc) and is available in 4' x 8' 3mm (1/8") thick sheets in black or white. It does expand and contract a little with heat and could be brittle if hit when it is extremely cold. It also would not let in any light. But if it is used for storage, I do not see that as a factor. Rough cost is $25.
