What vertical roller mill in the advantages of Asia?
Last activity 2014-11-24 11:11 PM
0 replies, 5104 views
jackson0
Reg. Nov 2014
Posted 2014-11-24 11:11 PM (#161765)
Subject: What vertical roller mill in the advantages of Asia?
Often known as clinker cement vertical mill vertical roller mill, vertical roller mill set-grinding, drying, grading about the complete, significantly less auxiliary equipment, a machine can, tiny footprint, lower dust pollution, generation of new environmentally friendly cement grinding equipment, in line using the national power conserving policy. With its very simple operation, straightforward maintenance, energy-saving impact is obvious to get utilized in lots of foreign cement manufacturing lines, but additionally makes great utilization of the outcomes at an global conference in 2009 SAF Toure on, to be the industry experts reached a consensus: vertical roller mill machine is superior, economical and practical advanced grinding equipment.As a consequence of technical limitations and lack of understanding, only portion on the cement firms test to run from the real production data of those enterprises, we reached the next conclusions:1, the system of investment, mixed with the real investment price range and companies conclude that despite the fact that the system is place right into a compact roller press, but his later on equipment and more, and thus large spot, substantial construction prices, the basic told, cement vertical roller mill investment and roll combined grinding machine system stress system pretty.2, energy consumption, the cement vertical roller mill system per ton of cement-saving technological innovation compared to the roller presses 3-5 degrees. It is reported that, Xinxiang City, the Fantastic Wall Machinery Co., Ltd. manufacturing of cement vertical roller mill single electrical energy consumption 25kWh / t, that is to say: a 5000TPD Cement clinker grinding year only saving: 15kWh / tX5000t / dX300d = 2250 íò kWh (ie Cement clinker grinding a yr can save five million degrees), energy-saving effect is very obvious.3, vertical roller mill for moisture and particle size are superior adaptability joint roller press grinding system. crusher machine.4, noise pollution, the cement vertical roller mill machine system should be much less compared to the mixed roller press grinding system.As a result, cement vertical roller mill system compared with all the roller press system has an absolute benefit, despite the fact that not still created ??a broad array of applications, but with all the implementation of power saving and low carbon growth policy needs, and cement enhance corporate environmental awareness, cement vertical roller mill are going to be entirely tapped market place.Cement is vitality consumption and emissions from massive industries, but our power consumption to cut back the speed and reduce the degree of emissions needs to be a large phase for five many years, one particular year a small phase, the future advancement from the cement industry advancement needs to be transformed to a larger degree, larger technologies, much more vitality conserving development.Contact US:info@stoneminingmachine.com
