Can I safely run the furnace in my horse living quarters while traveling on the road?
Last activity 2014-11-15 11:15 AM
5 replies, 5950 views
ddkrueger
Reg. Dec 2003
Posted 2014-11-13 4:43 PM (#161551)
Subject: Can I safely run the furnace in my horse living quarters while traveling on the road?
I do cowboy mounted shooting. I have a shoot this weekend and was wondering if it is safe to run the furnace while traveling because the temp. is in the low 20's. We are shooting at an indoor arena. We usually don't travel with the horse trailer when it is cold.
justgurn
Reg. Oct 2010
Posted 2014-11-14 8:26 AM (#161553 - in reply to #161551)
Subject: RE: Can I safely run the furnace in my horse living quarters while traveling on the road?
Keyword "Safe" not can you or have you. It is not safe to run anything off gas when traveling. Good luck at the shoot.
Posted 2014-11-14 9:48 AM (#161555 - in reply to #161551)
1000500100100100252525
I would worry about gas leak
Miner
Reg. Jul 2009
Posted 2014-11-14 10:27 AM (#161559 - in reply to #161551)
The furnace will not vent properly possibly causing a carbon monnxide buildup in the LQ.  A few years ago, a well known trainer from Texas lost his son and a friend from carbon monoxide poisoning because the furnace was left on while going down the road.
CTRider
Reg. Sep 2009
Posted 2014-11-14 1:23 PM (#161565 - in reply to #161551)
10010010025
You probably will not be needing the water so just winterize your lines. We have hauled with it cold though with no issues. Went camping with 6 inches snow on the ground and went over a pass and it was 17 degrees on top. Trailer was toasty warm when we left the house. Maybe we were just lucky. But you could blow out your lines and use bottled water for drinking and wet wipes for cleaning up from riding.
Posted 2014-11-15 11:15 AM (#161582 - in reply to #161551)
The furnace will not keep your underbelly pipes very warm. I would be concerned about the POSSIBILITY of a fire due to the drafting effect on the furnace while towing.
