Lights
Last activity 2014-11-13 2:39 PM
1 replies, 3798 views
Latts55
Reg. Feb 2014
Posted 2014-11-13 11:49 AM (#161547)
Subject: Lights
can anyone tell me why when I truck is hooked to my trailer,my inside lights don't work? They only work with my battery on the trailer. Tks
Posted 2014-11-13 2:39 PM (#161549 - in reply to #161547)
Subject: RE: Lights
Check the truck's plug receptacle at the one o'clock position for 12 v. If there is none, check the truck's fuse box for a blown fuse. If it's a Ford SD, it will be the fourth maxi fuse from the front on the engine side. (30A) Also if it's a Ford, the key will have to be ON and if it's a diesel, some years only power the circuit when the motor is running. If that doesn't work, dissemble and check the trailer's plug at the same location for a loose or broken wiring connection.
