Electric Water Heater No Vent
Last activity 2014-11-01 11:51 AM
2 replies, 3956 views
poshponies
Reg. Mar 2013
Posted 2014-11-01 10:45 AM (#161348)
Subject: Electric Water Heater No Vent
Saw an electric (under sink) water heater that was not vented to the outside of the trailer. The generator has to be running in order to heat the water; I believe it is a six gallon size. I can't find this heater anywhere--it isn't an Atwood or Suburban. Has blue foam as an outer cover. Does anyone know what brand it could be? I really do not want to install propane/lines/tanks/CO2 monitor/anything else that goes along with gas heaters. I want simple but do not want an on-demand type.
poshponies
Reg. Mar 2013
Posted 2014-11-01 10:56 AM (#161349 - in reply to #161348)
Subject: RE: Electric Water Heater No Vent
Wanted to add it isn't blue 'foam' on the outer cover it is a blue hard plastic cover. duh
cajunmuleman
Reg. Oct 2011
Posted 2014-11-01 11:51 AM (#161350 - in reply to #161348)
You can find several different styles and types at Home Depot, Lowes, etc. or local plumbing supply houses. Besides physical dimensions, make sure to look at amp draw. Check on you generator KW to make sure you don't overload it.
