Axles Bad Again and Brake Locked Up
Last activity 2014-09-02 11:40 PM
19 replies, 8533 views
davang55
Reg. Feb 2014
Posted 2014-08-30 9:48 PM (#160588)
Subject: Axles Bad Again and Brake Locked Up
Got a text from my wife while I was stuck on weekend call. The left rear brake on her 4H Sundowner Sunlite LQ locked up. Also the wires to the left front had been damaged. Daughter heard it as they were pulling in. A guy came out to work on it and also said the axles were bent again. These are the second pair, getting about 3 years per set. She hauls usually 4 big barrel horses and lord knows what she drives over to get those kids to the event.I'm not sure but I believe they are 7K Dexter torsion axles. Should I just replace with the same or is there something better? Can I go up to 8K?Also I might want to go to a 17.5 tire and wheel. Any tips for that as well? Thanks in advance. HAppy Labor day!!
trbomax
Reg. May 2014
Posted 2014-08-31 10:00 AM (#160589 - in reply to #160588)
Subject: RE: Axles Bad Again and Brake Locked Up
How big and heavy is this trailer?
beeoerdog
Reg. Jan 2014
Posted 2014-08-31 10:11 AM (#160590 - in reply to #160588)
10010010010025
Ditto....have the trailer weighed loaded then talk to the techs at Dexter and then your wife about her driving technique.........(apologies to the wife)
trbomax
Reg. May 2014
Posted 2014-08-31 10:18 AM (#160591 - in reply to #160588)
I was going to mention driveing habits as well but didnt want to be first!
kooner
Reg. Jun 2011
Posted 2014-08-31 11:50 AM (#160592 - in reply to #160588)
you said the brake was locked up?? so why do you think and axel is bent? first good sign of this is tire wear. I have been around alot of heavy trailers and yes I have seen bent ones but they have really been abused by heavy over loading and tight turns.
trbomax
Reg. May 2014
Posted 2014-08-31 3:44 PM (#160593 - in reply to #160588)
after thinking about this,the scenario could be that she hit something in the road or drug the left side of the trailer into/over something resuting in tearing the wires out of the front brake and bending the spindle of the rear axle to the point that the drum was jammed into the shoes and backing plate. I just cant imagine how much force that would take on a 7k axle assy.
trbomax
Reg. May 2014
Posted 2014-08-31 3:50 PM (#160594 - in reply to #160588)
another thing,as close as the tires run to the box she could have done what I said above and jammed the tire into the side of the box,thus keeping it from rotateing.either way the axle is toast.
Posted 2014-08-31 5:25 PM (#160596 - in reply to #160588)
Another possibility is a very tight turn that scrubs the tires & axles.  A left turn maneuver would pivot the trailer around the left side tires bending the stubs.  Maybe catching a brake wire too.
Posted 2014-08-31 5:28 PM (#160597 - in reply to #160589)
Originally written by trbomax on 2014-08-31 7:00 AM
Any four horse plus Living Quarter is a Big and Heavy trailer to me.
beeoerdog
Reg. Jan 2014
Posted 2014-08-31 6:24 PM (#160598 - in reply to #160588)
10010010010025
I agree......7,000 lb axles seem a little light
trbomax
Reg. May 2014
Posted 2014-08-31 7:56 PM (#160599 - in reply to #160588)
Thats what I was getting at. Some manufacturers will build right to the limit and then the LQ people get it and then..........................
trbomax
Reg. May 2014
Posted 2014-08-31 8:06 PM (#160600 - in reply to #160588)
Actually,a four horse with an 8' SW would probably be close but OK at 14000 gross if the horses were only 1500# or so..Our 2 H x8'SWLQ has 2 5200# dexters and w/o animals only carries 6900# on the axles.
davang55
Reg. Feb 2014
Posted 2014-09-01 5:57 PM (#160604 - in reply to #160588)
Thanks for all the input. THe brakes "locked" because a spring broke. They didn't actually lock I guess. They're getting home soon so I can see what I got. Thanks again.Jeff
davang55
Reg. Feb 2014
Posted 2014-09-02 7:01 AM (#160612 - in reply to #160588)
OK the trailer's home and the axles ARE NOT bent, they are crowned in the middle I believe that is how they come from the factory. If they were bent they'd be sagging correct?
kooner
Reg. Jun 2011
Posted 2014-09-02 7:53 AM (#160614 - in reply to #160588)
look at the trailer from a little distance and see if they look right and also from the rear, most trailers with bent axels look like the tires lean to the outside, do you have un even tire wear??? this is the real indicator of something wrong.
davang55
Reg. Feb 2014
Posted 2014-09-02 8:17 PM (#160617 - in reply to #160614)
They look like they're straight up. There's a tad bit more wear on the inside tread bar BUT not as severe as it was the last time I changed the axles.
davang55
Reg. Feb 2014
Posted 2014-09-02 9:50 PM (#160619 - in reply to #160588)
Now the brakes:The 2 wires from the harness leading to the left front brake broke off at the butt connector, the cable clamp was missing that holds the plastic conduit tube of the harness. I used the ohmmeter to see which wire was ground since they are BOTH red and they both check GROUND?? SHows zero resistance (they're still detached from the magnet art this time). They are connected in parallel to the rear brakes so those are grounded too.I don't get it. I took the cover off the outlet box that holds all the connections and nothing is burnt or frayed.ALSO the guy that made the temporary fix said that the brakes had gotten overheated because the metal frame was reddish in color. I saw a picture of a brand new brake assembly and it's painted that way is it not?Should I just replace all the brake assemblies? I can get them for $205 each minus 10% and free shipping from FinditParts.com. Or just replace the one assembly? I'm afraid if one spring broke another might?I know too many questions.Thanks
beeoerdog
Reg. Jan 2014
Posted 2014-09-02 10:38 PM (#160620 - in reply to #160588)
10010010010025
You can get the brakes on Ebay for about $50.00/wheel. Search Dexter Trailer Brakes. Dexter has a lot of brake info on their website.
beeoerdog
Reg. Jan 2014
Posted 2014-09-02 11:07 PM (#160621 - in reply to #160588)
10010010010025
ETrailer.com also has a lot of articles about brakes.
Your zero resistance reading could be because the resistance of the magnets is only 3-4 ohms.
Posted 2014-09-02 11:40 PM (#160622 - in reply to #160588)
There is no polarity on the brake magnets. Either wire can be a ground or hot wire. It's easier to check for voltage when trouble shooting. If you solder the joints and use shrink wrap tubing on the splices, you can be assured of the best continuity and mechanical connection. If you have access to aircraft or marine AMP butt splices and a crimping tool, the job is easier and faster.
On E bay there are two types of full brake assemblies, Dexter OEM and less expensive Chinese copies. The EBay pricing is very nominal for the complete units with free shipping. Change both brakes on the same axle. As long as you are replacing one axle's brakes, changing them on both axles, will ensure a long and trouble free usage, without having to go back and readdress the issue again.
I've replaced the Dexter brake assemblies with new Dexter products, and found then to be complete and trouble free. I don't know what the Chinese products are like, but with the nominal savings, I wanted the OEM products.
