Removing boards from WW Trailer floor
Last activity 2014-08-14 12:21 PM
2 replies, 4690 views
Daenerys
Reg. Jul 2014
Posted 2014-07-31 9:35 AM (#160207)
Subject: Removing boards from WW Trailer floor
The 1995 WW trailer I have has the boards in between two lips, I can't seem to figure out how they can be removed and replaced. Any suggestions?
kooner
Reg. Jun 2011
Posted 2014-07-31 11:52 AM (#160209 - in reply to #160207)
Subject: RE: Removing boards from WW Trailer floor
are you talking side or front and rear?? on most older trailers to replace the floor you will need to remove the rear piece of metal to slide the boards out and then re weld it.
Daenerys
Reg. Jul 2014
Posted 2014-08-14 12:21 PM (#160411 - in reply to #160207)
I have a WW trailer that I just started working on this! Mine had a small slot on the top lip in the tack room. We actually cut a larger one with an angle grinder. Then cleaned up the frame and the new boards slid in pretty easily. Check out my blog I'm detailing how we are doing the reflooring.
http://www.canihaveapony.blogspot.com/search/label/Horse%20Trailer%...
