Heater in LQ question.
Last activity 2014-08-11 10:29 PM
20 replies, 9921 views
BILLYS
Reg. Apr 2014
Posted 2014-07-23 9:02 PM (#160118)
Subject: Heater in LQ question.
Hi, Wondering what you guys do for a portable heater in the trailer? Thanks for looking.
Linda Y
Reg. May 2007
Posted 2014-07-24 8:24 AM (#160123 - in reply to #160118)
Subject: RE: Heater in LQ question.
10010010025
I just use a little ceramic heater that I got at Lowe's. It is PLENTY warm enough! Some people use propane heaters. I just can't bring myself to trust propane in a trailer.
Dunoir1
Posted 2014-07-24 8:24 AM (#160124 - in reply to #160118)
I have a portable electric heater (about $15-$20) that my HOnda 2000 generator will run if I don't have electric.  The AC unit has a heat strip, but it doesn't work that great.  I love the portable one as you can set it for a certain temp and it will turn on/off as needed and you can adjust it easily. My trailer is a 2H with 5' short wall, so it's not a huge area, but it keeps it toasty.  The only time it didn't heat it up enough it was 18 degrees outside!  yiks  much too cold to camp.
Three 4 Luck
Posted 2014-07-24 9:29 AM (#160130 - in reply to #160118)
I used my dog as a heat source one time in 20 degree weather. LOL AC/heat strip was not working, and my little ceramic heater went out. I have a german shepherd, so I cuddled up with her under some blankets. It was still cold, but I didn't freeze to death.
cremevette
Reg. Dec 2003
Posted 2014-07-29 7:47 AM (#160189 - in reply to #160118)
I have a 1500 watt cool touch heater from Walmart with a Honda 2000. It's either a Sunbeam or Honeywell. I've had several different kinds and they're all about the same. The coldest I stayed in my finished gooseneck was 27 degrees. The heater was up in the goose, I had a down comforter over me, two more blankets, AND the big black lab and it was AWFUL cold nonetheless. I'm not much for cold weather camping, though.
BILLYS
Reg. Apr 2014
Posted 2014-07-29 10:56 AM (#160191 - in reply to #160189)
Originally written by cremevette on 2014-07-29 7:47 AM
With this you'll need to run the gen all nite?
cajunmuleman
Reg. Oct 2011
Posted 2014-07-29 2:42 PM (#160194 - in reply to #160118)
Yes ( only if you want to stay warm ) just kidding - the correct answer is yes
kowgurl62
Reg. Aug 2009
Posted 2014-08-05 12:24 PM (#160286 - in reply to #160118)
If you are talking about camping overnight without power, in a trailer without lq, the one or two burner propane heaters like you would use in a house are awesome. There are also tanktop heaters, but I wouldn't trust them inside a confined space. The only thing with using propane open flame inside a confined space is to make sure you have a window, or your bathroom vent open for fresh air. I have an electric space heater I run to keep pipes from freezing when the trailer is at the barn. I've even used my cooktop as a source of heat in an emergency.
cajunmuleman
Reg. Oct 2011
Posted 2014-08-05 5:32 PM (#160294 - in reply to #160118)
Please be careful using a stove top for comfort heating.Also when using propane heaters indoors be sure to have a detector that is working. Some of these heaters have low oxygen sensors and tip over shut off
Posted 2014-08-06 5:42 AM (#160300 - in reply to #160118)
A small ceramic heater is able to comfortably heat a 13' LQ in below freezing weather.
Do not use any open flame heaters or heat sources within the confines of your trailer. Only appliances that are directly vented and approved, should be considered. That are many instances of CO poisoning when the wrong heat source is used.
BILLYS
Reg. Apr 2014
Posted 2014-08-06 11:10 AM (#160305 - in reply to #160118)
"A small ceramic heater is able to comfortably heat a 13' LQ in below freezing weather"
Do you recomend a certin one?
BILLYS
Reg. Apr 2014
Posted 2014-08-06 11:12 AM (#160307 - in reply to #160118)
Looks like the ceramic heaters are electric??
cajunmuleman
Reg. Oct 2011
Posted 2014-08-06 2:18 PM (#160310 - in reply to #160118)
yes, ceramic heaters are electric and require electricity - either shore power or generator
BILLYS
Reg. Apr 2014
Posted 2014-08-06 4:12 PM (#160313 - in reply to #160118)
But running a gen all nite, won't that tourque people?
cajunmuleman
Reg. Oct 2011
Posted 2014-08-07 7:59 AM (#160320 - in reply to #160118)
not with the right generator. Honda, yahamha, onan and a few others. Most places we go that don't have hook ups everyone is running generators.
diggerdoo
Reg. Oct 2009
Posted 2014-08-07 10:05 AM (#160325 - in reply to #160118)
I would rather listen to a generator than a bunch of drunks partying all night.  Or dogs barking.
BILLYS
Reg. Apr 2014
Posted 2014-08-07 11:07 AM (#160327 - in reply to #160118)
Ill give it a try. Dogs don't bark, we don't party to hard and we have 2 honda 2000s. Thanks. Now to find the right heater.
Posted 2014-08-07 9:48 PM (#160334 - in reply to #160118)
Walmart, home centers, hardware stores, Tractor Supply, etc., all sell comparable units. You will want one with an adjustable thermostat and a variable speed fan. Many use 1350Ws at the highest setting, so running one on a 2000W generator is doable. Expect to pay ~$30-$35, sale times are cheaper.
BILLYS
Reg. Apr 2014
Posted 2014-08-08 11:05 AM (#160343 - in reply to #160334)
Originally written by gard on 2014-08-07 9:48 PM
Thank you....
gonzo1066
Reg. Oct 2010
Posted 2014-08-11 10:16 PM (#160371 - in reply to #160130)
Originally written by Three 4 Luck on 2014-07-24 7:29 AM
How many dogs would it take for maybe-10 degree nights?? Would it help heat the coach if you fed the dog beans and bacon before bedtime??
Posted 2014-08-11 10:29 PM (#160372 - in reply to #160118)
There's a musical group titled the "Three Dog Night". It's name came from sleeping in the Australian bush, with three dogs for warmth, during cold nights.
