lunde lift
Last activity 2014-07-15 10:20 AM
6 replies, 5015 views
spuddnut
Reg. Jul 2014
Posted 2014-07-11 7:16 PM (#159847)
Subject: lunde lift
Hello I have a lunde lift single leg elect hydraulic jack that wants to freefall going down even when I release the button it will go all the way down with moter off?? Fluid is full and I cleaned the poppet and the valves any help greatly apreciated.
beeoerdog
Reg. Jan 2014
Posted 2014-07-11 9:21 PM (#159848 - in reply to #159847)
Subject: RE: lunde lift
10010010010025
Hi.... click the search function...there are previous discussions about servicing the Lunde lift jack
beeoerdog
Reg. Jan 2014
Posted 2014-07-11 9:50 PM (#159849 - in reply to #159847)
10010010010025
whoopps...posts are too old and don't show up.....google Lunde lift and they will show up...interesting one by justgum on servicing
spuddnut
Reg. Jul 2014
Posted 2014-07-11 9:52 PM (#159850 - in reply to #159847)
Thanks but it looks as though the farthest I can search is the last 360 day-- I'm not very adept on a computer. I found some past comments when I did a search on line for lunde lift problems and some on this site showed up but nothing like my problem and those posts were 2012 or so. I was able to slow downward travel by installing a restrictor on the return line so it is not so scary.
Posted 2014-07-11 11:28 PM (#159853 - in reply to #159847)
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=169...
justgurn
Reg. Oct 2010
Posted 2014-07-15 9:09 AM (#159902 - in reply to #159847)
The unit has two poppets. It is easy to see the first because it is on the front side. The second is located on the backside of the unit. You will have to remove the powerhead.Please make sure you place the trailer on jack stands before removing a poppet.Best of luck. jg
spuddnut
Reg. Jul 2014
Posted 2014-07-15 10:20 AM (#159904 - in reply to #159847)
Thank you for the location of 2nd poppet I did not see that one and had to let the unit go as she had a show in Calif.It will be back this week and will check that out.
