Poll PLUMBING
Last activity 2014-05-21 3:16 PM
5 replies, 4469 views
Nugget
Reg. Mar 2014
Posted 2014-05-20 1:33 PM (#159140)
Subject: PLUMBING
just wanted to know if it was safe to make a 1 inch hole with a hole saw in the I beams underneath the trailer just to run my hot and cold water line I plan on using grommets so the metal doesn't cut the pipe...... all in put is welcomed...
kooner
Reg. Jun 2011
Posted 2014-05-20 1:45 PM (#159141 - in reply to #159140)
Subject: RE: PLUMBING
any hole you cut in metal has to weaken it, I looked and our C&c is underneath the I beams.If you run them through or under be sure to pad the pipes so they will not rub.
Nugget
Reg. Mar 2014
Posted 2014-05-20 3:53 PM (#159142 - in reply to #159140)
I just need to figure out how to get up and across the trailer
kooner
Reg. Jun 2011
Posted 2014-05-20 4:16 PM (#159143 - in reply to #159140)
I guess my next question for you is how much room do you have from the ground to the bottom of your trailer? I am betting where you need to run water lines is no where close to the ground for clearance. I would do my best not to cut holes in the beams.
kowgurl62
Reg. Aug 2009
Posted 2014-05-21 10:37 AM (#159157 - in reply to #159140)
Most horse trailers now don't run the plumbing outside of the lq area, they use something to cover the lines where they go past doorways and then through the cabinets. If they are run outside they will be more prone to freezing. The less holes in the floor of your trailer the better. Build a boxed cover to conceal the pipes, then cover it with carpet. If pictures would help I can get some for you.
Nugget
Reg. Mar 2014
Posted 2014-05-21 3:16 PM (#159162 - in reply to #159140)
HECK yeah guys thanks a lot I can actually run it on the inside I just have to do a little rigging but it will still work guys all pictures are wonderful to have thanks so much
