sealing mat seams
Last activity 2014-05-01 9:37 PM
7 replies, 5574 views
Slidinspots
Posted 2014-04-29 5:38 AM (#158851)
Subject: sealing mat seams
Is it possible to "seal" trailer mat seams? I have a horse who pees in the trailer almost every time he is loaded. I put lots of shavings to soak it up but of course it can't get it all before some runs through the mat seams to the floor.
trot-on
Reg. Dec 2009
Posted 2014-04-29 8:26 AM (#158854 - in reply to #158851)
Subject: RE: sealing mat seams
I put Gorilla tape on mine, and will check under the mats in about 2 more trips to see if it has worked. I do use shavings too, but some urine was still seeing under. The Gorilla tape is staying in place/stuck
Posted 2014-04-30 10:19 PM (#158883 - in reply to #158851)
Originally written by Slidinspots on 2014-04-29 5:38 AM
Plan on pulling the back mats on a routine basis and washing that area...that or try training the horse NOT to pee in the trailer...:)
Slidinspots
Posted 2014-04-30 10:29 PM (#158884 - in reply to #158883)
LOL!! I trained him to pee in his stall before I leave. But coming home, he will not pee on command in the arena or in the dirty shavings. He wants a stall...
Patti
trot-on
Reg. Dec 2009
Posted 2014-05-01 9:35 AM (#158891 - in reply to #158851)
I know some train them to not ee in trailer, but I want mine to pee when he needs to, and not "hold it". And on a long haul, I don't want them to hold it for hours.
Wrangler48
Reg. Jul 2010
Posted 2014-05-01 3:56 PM (#158898 - in reply to #158851)
Hi, there is calking material that is temporary- 'Seal and Peel' is one name- they are two or three brands available at ACE and other hardware stores. it is intended to seal for cracks at window and doors. I have used it on mat seams and side by walls- it holds up against the urine so it does not run straight through. the nice part is use it for a period of time (weeks/months) and then peel it off to pull mats and wash down the floor underneath as maintenance.
Slidinspots
Posted 2014-05-01 9:35 PM (#158901 - in reply to #158898)
Thanks Wrangler!! I will give it a try.
Slidinspots
Posted 2014-05-01 9:37 PM (#158902 - in reply to #158891)
trot-on exactly! When they are in the trailer for 8-12 hours I want them to pee!
