water in gen. fuel tank
Last activity 2014-04-28 10:59 PM
2 replies, 3599 views
tango97
Reg. Oct 2011
Posted 2014-04-27 5:27 PM (#158816)
Subject: water in gen. fuel tank
Hi all keep getting water in fuel . vent is open .tank is about 90% full. I put in a inline bowl to kept up with draining the water. Any help Please. Steve
Posted 2014-04-27 6:58 PM (#158817 - in reply to #158816)
Subject: RE: water in gen. fuel tank
The source of the water has to be determined. Is the fuel contaminated when purchased or later due to inclement weather and moisture? If the only external source of entry is through your filler cap with a built in vent, it can be modified or in many cases, replaced with a different design. You only have one or two ports into the tank, so figuring out any moisture entry shouldn't be difficult.
I would use an ethanol fuel additive to your tank on a regular basis. It acts as a dry gas, and not only removes the excess moisture due to the ethanol, but prevents corrosion to any of the aluminum fuel system parts.
Posted 2014-04-28 10:59 PM (#158845 - in reply to #158816)
Like Gard said...you have to determine where it is coming from...now if you are NOT using it but on a monthly basis, I'd lean toward the ethanol sucking moisture out of the air...
