Help with sidekick trailer lights
Last activity 2014-04-23 10:29 PM
5 replies, 4119 views
gfnails
Reg. Apr 2014
Posted 2014-04-23 4:37 PM (#158783)
Subject: Help with sidekick trailer lights
I bought a used sidekick. No manual and the lights outside and inside back where horses go do not work, I have no idea what I am doing! Can anyone advise? Thank you
beeoerdog
Reg. Jan 2014
Posted 2014-04-23 5:42 PM (#158784 - in reply to #158783)
Subject: RE: Help with sidekick trailer lights
10010010010025
Assuming you have found a switch, the lights need 12v, probably from your truck. Try turning on the lights with the trailer plugged in. Wiring at the plugs needs to be correct also in order for everything to work properly.
gfnails
Reg. Apr 2014
Posted 2014-04-23 6:49 PM (#158785 - in reply to #158784)
They won't work with it plugged in at all , yes I found the switch, I wish I could find an owners manual but company out of business
beeoerdog
Reg. Jan 2014
Posted 2014-04-23 7:02 PM (#158786 - in reply to #158783)
10010010010025
with the trailer plugged in, does everything else work? brake lights, running lights, brakes?
skippyvcu
Reg. May 2006
Posted 2014-04-23 8:01 PM (#158787 - in reply to #158783)
If you have a Ford truck, the key must be on for there to be power to the auxiliary lights.
Posted 2014-04-23 10:29 PM (#158788 - in reply to #158783)
If you have a Ford diesel, the truck must be running to feed the stall and exterior lighting circuits. They are not powered by the LQ's batteries or converter. Either way, running or stationary, the lighting circuit is powered from the B+ pin on the trailer plug.
