trailer lights
Last activity 2014-04-16 1:20 PM
6 replies, 4122 views
bailbud
Reg. Apr 2014
Posted 2014-04-15 11:29 PM (#158681)
Subject: trailer lights
bailbud
Reg. Apr 2014
Posted 2014-04-15 11:36 PM (#158682 - in reply to #158681)
Subject: RE: trailer lights
I have a Classic 3 horse gn . the clearance light on the front left of the trailer works sometimes and sometimes not ,changed bulbs still same problem . all the wires are run inside the frame of the trailer any ideas how to find where the break or bare wires maybe ?
Posted 2014-04-16 12:03 AM (#158684 - in reply to #158681)
Look inside the bulb's base for corrosion and the light's frame grounding for an adequate circuit. The ground is either completed by the frame against the trailer body, or a second wire running to a grounding terminal. Once the base is cleaned, dielectric grease can be added that lowers the incidence of reoccurring corrosion.
beeoerdog
Reg. Jan 2014
Posted 2014-04-16 9:58 AM (#158686 - in reply to #158681)
10010010010025
sometimes the light base is grounded to the frame by way of a pop rivet.....drill it out and install new rivet ( after checking that socket is free of corrosion )
Posted 2014-04-16 12:19 PM (#158688 - in reply to #158686)
Originally written by beeoerdog on 2014-04-16 6:58 AM
AND before installing that new rivet, add a touch of "Noalox" or similar electrical anti oxidation paste.  It's cheap insurance against redoing the work in a few years.
bailbud
Reg. Apr 2014
Posted 2014-04-16 12:46 PM (#158689 - in reply to #158681)
thanks guys , done did all that. its a sealed light with a good ground . have checked and am not getting batt voltage to the light
beeoerdog
Reg. Jan 2014
Posted 2014-04-16 1:20 PM (#158690 - in reply to #158681)
10010010010025
OK.....start by pulling out the light and checking the connections inside the frame...there should be enough wire at every connection back to the trailer plug. Leave the lights on and wiggle all connections until you find the loose connection. Some trailers have panels on the inside that can be removed for access to the wiring. If it is not the connection at the first point, I would go to the next closest point that is working properly....you will be able to see which direction the wire runs when you pull out the fixture.
