Living quarter batteries
Last activity 2014-04-08 3:23 PM
7 replies, 11974 views
Marla
Reg. Mar 2008
Posted 2014-04-02 1:09 AM (#158400)
Subject: Living quarter batteries
500
I want to replace the deep cycle batteries in the living quarter before my departure for Alaska. What brands do you all like and why? Will deep cycle batteries crank my generator, or do I need to keep my automotive battery for that?
bigriverjeff
Reg. Sep 2006
Posted 2014-04-02 8:30 AM (#158405 - in reply to #158400)
Subject: RE: Living quarter batteries
for deep cycle batteries I have been using Optima blue tops 31 group they cost a lot but in my opinion worth every penny they cost!
Posted 2014-04-02 10:03 AM (#158410 - in reply to #158400)
You can use a deep cycle battery for starting, there is no need to utilise a second type. The initial amps necessary for starting your generator, is quite small in relation to what is available from your LQ batteries. There are many types of deep cycle batteries that are available, wet cell, gel etc. The common RV/marine types sold at auto parts stores are adequate, but if you are going to be totally dependent on their performance, a true marine battery will offer the best performance.
If properly maintained, wet cell marine batteries can usually be recharged up to 400 times at about 70 - 80% of their capacity. Their plates are extra heavily constructed, so as not to be damaged by vibrations within a rough environment. If you anticipate heavy loads and long drawing cycles, I would recommend a true marine battery available at any marina. If your needs are similar to what you experience now, the marine/RV variants work well at a much less expensive purchase price.
Purchase your batteries locally and look for the best warranties. Batteries are sold like mattresses, with somewhat set prices. Shop for the best pricing, and argue that the purchase of two is worth a discount. Batteries are like trailers, there is no BEST battery that suits everyone's needs.
Enjoy your trip, it sounds like an event to be remembered for a life time.
Posted 2014-04-02 12:06 PM (#158413 - in reply to #158400)
When you replace your batteries...you are replacing both of them...because weaker battery will draw down the new one and will shorten its life. If one still shows good, keep it for a spare for another vehicle that only takes one battery.Everything you want to know about batteries... http://www.batteryfaq.org
Marla
Reg. Mar 2008
Posted 2014-04-04 8:51 PM (#158463 - in reply to #158400)
500
Thanks for all your replies. I have been doing a lot of reading and now know more than I ever imagined I would about batteries! Great info.
RSTedman
Reg. Mar 2014
Posted 2014-04-05 9:33 AM (#158475 - in reply to #158400)
I have had the best luck with 2 6 volt golf cart batteries. The charge seem to last longer and the batteries are good for years.
rockyrider
Reg. Jun 2004
Posted 2014-04-08 2:22 PM (#158552 - in reply to #158400)
100100100
Hey Gard, Or anybody familiar with Battery Tender, can I leave my batteries in the battery box connected together and just clip battery tender to one battery? Will this keep both charged?Just had shoulder surgery and won't be using trailer for some time, and am unable to lift them out of box.
beeoerdog
Reg. Jan 2014
Posted 2014-04-08 3:23 PM (#158556 - in reply to #158400)
10010010010025
clip to positive of one battery and negative of the other....that will keep both batteries charged properly
