help finding this trailer light
Last activity 2014-03-23 9:27 PM
11 replies, 7146 views
brooksbarrelhorses
Reg. Aug 2005
Posted 2014-03-21 10:16 PM (#158203)
Subject: help finding this trailer light
attaching pictures..the number on the front of the light reads SAE(2)R 04 DOT
Posted 2014-03-22 9:13 AM (#158208 - in reply to #158203)
Subject: RE: help finding this trailer light
That # you posted looks like a lense code number. Do you see anything in the link I've posted that looks like your light? Is it a marker, stop/tail/turn signal light, load light, etc...? Your picture no workie..
http://www.actionfabrication.com/suplier_catalog/buyers_electrical_and_lighting.pdf
 Your local truck stop will probably have what you're looking.
Edited by retento 2014-03-22 9:15 AM
Posted 2014-03-22 9:34 AM (#158209 - in reply to #158203)
EBay has hundreds of light assemblies for sale if you can't find anything locally. You also may consider a conversion to a newer LED replacement, which looks like and replaces the older bulb styles.
Sometimes it's easier to replace the whole assy, rather than messing with older light bases, corroded bulb sockets and missing parts. It also allows you to reseal the base to the trailer, which is often a source of roof leakes.
Posted 2014-03-22 12:48 PM (#158210 - in reply to #158209)
Originally written by gard on 2014-03-22 9:34 AM
Sometimes it's easier to replace the whole assy, rather than messing with older light bases, corroded bulb sockets and missing parts. It also allows you to reseal the base to the trailer, which is often a sourceĀ of roof leakes.
+1
brooksbarrelhorses
Reg. Aug 2005
Posted 2014-03-23 9:43 AM (#158220 - in reply to #158203)
it is a light in the horse area. it does not wire in, but is one solid piece from what I can tell that is the light, lens, and buld and wires plug into it. i has 3 places to plug into on is stop & turn, ground and tail. i will work on pics.
brooksbarrelhorses
Reg. Aug 2005
Posted 2014-03-23 10:07 AM (#158221 - in reply to #158203)
pics
Color01
Reg. Jul 2013
Posted 2014-03-23 10:26 AM (#158222 - in reply to #158203)
I have a few of these lights left with the red lens.
hornet
Posted 2014-03-23 11:35 AM (#158223 - in reply to #158222)
Any autoparts store, Orschelens or Tractor Supply should have that, it's just a sealed reverse light.
hornet
Posted 2014-03-23 11:39 AM (#158224 - in reply to #158223)
http://www.oreillyauto.com/site/c/detail/OPT0/BU70CBP.oap?ck=Search...
Posted 2014-03-23 2:55 PM (#158226 - in reply to #158203)
Several options depending on size... http://accessories.etrailer.com/trailer/Led%20Backup%20Lights
MrSteve
Reg. Jul 2012
Posted 2014-03-23 4:10 PM (#158228 - in reply to #158203)
This is the exact light you need... http://www.etrailer.com/Trailer-Lights/Optronics/BU70CB.html to make it easier for you, any truck stop, napa (hit and miss with other auto parts stores) and so on will have them in stock... 5.00 to 7.00 each (yes it plugs in, no bulb replacement, whole assembly is replaced).
brooksbarrelhorses
Reg. Aug 2005
Posted 2014-03-23 9:27 PM (#158232 - in reply to #158203)
great thank you
