95 sundowner
Last activity 2014-03-20 9:23 AM
10 replies, 7166 views
push350z
Reg. Mar 2014
Posted 2014-03-16 1:26 PM (#158082)
Subject: 95 sundowner
So we are looking for trailers and came across a 95 sundowner. I saw issues with rusting of the frames and when we looked at this one we saw rusting. I just wanted to show a couple shots and see what others had to say. Here are a few pics:
This is on the inside of the trailer along the bottom wall near the rear:
This is the outside under the wheel arch where you can begin to see the rusting:
https://drive.google.com/file/d/0Byrsc_zBwqUQRzNuTkRqeUlxTms/edit?usp=sharing
Here's a look deeper into the wheel well:
https://drive.google.com/file/d/0Byrsc_zBwqUQbUt6QnczeWNib1E/edit?usp=sharing
Is this more or less cosmetic? Or should it be something to be legitimately concerned with?
Edited by push350z 2014-03-16 1:29 PM
push350z
Reg. Mar 2014
Posted 2014-03-16 1:31 PM (#158084 - in reply to #158082)
Subject: RE: 95 sundowner
Sorry, screwed up links in original post:
Bottom wall
Wheel well
Deeper into wheel well
Edited by push350z 2014-03-16 1:32 PM
push350z
Reg. Mar 2014
Posted 2014-03-17 11:56 AM (#158108 - in reply to #158082)
Anyone?
Posted 2014-03-17 12:11 PM (#158109 - in reply to #158082)
Can't get your links to work on my old computer...
Edited by retento 2014-03-17 12:13 PM
push350z
Reg. Mar 2014
Posted 2014-03-17 2:54 PM (#158112 - in reply to #158082)
This may work: photo 20140316_121217_zps19a26158.jpg
Color01
Reg. Jul 2013
Posted 2014-03-17 2:58 PM (#158113 - in reply to #158082)
I would shop around for something better.
Posted 2014-03-17 4:59 PM (#158117 - in reply to #158082)
"I would shop around for something better."
Ditto. Unless you are well versed in welding and have cheap access to materials, that is a trailer to avoid.
horsey1
Reg. Dec 2004
Posted 2014-03-18 8:31 AM (#158135 - in reply to #158082)
Just a 20 year old all steel trailer, that from the Cinci note, has also been up north. Looks like what I'd expect. Maybe you need to shop newer.
flyinghfarm
Posted 2014-03-18 11:25 AM (#158138 - in reply to #158082)
1000100100
I have a 95 Sundowner 2 horse steel, and it does not have any of those issues.... but it lives below the Mason Dixon, not out in the salt/ chemicals of northern areas....
diggerdoo
Reg. Oct 2009
Posted 2014-03-20 9:13 AM (#158168 - in reply to #158082)
I just sold my 95 Sundowner all steel last weekend.  I have owned it since 1998 and I live in Iowa.  It looks brand spanking new compared to that.
Spin Doctor
Reg. Nov 2008
Posted 2014-03-20 9:23 AM (#158169 - in reply to #158082)
Depending on price and your skills, might be worth a shot. I did one that was rusted out like this a few years ago. Just took angle iron that wraped under the existing angle iron, with the top being back into the sheet metal enough to get out the rust. $300 of steel, $30 of paint and welding rod, a day later, looked fine on the outside. Still could see rusted sheet on the inside. But for this ranch trailer, worked fine.
Be honest with yourself on your welding/fabrication skills as it is a lot cutting and fitting...
Good luck.
