Trailer Interior Light
Last activity 2014-03-04 2:01 PM
9 replies, 5680 views
mulerider01
Reg. Aug 2012
Posted 2014-03-03 9:25 AM (#157797)
Subject: Trailer Interior Light
I cannot find why my center strings of fluorescent lights will not work,fuses seem fine,have checked bulbs seem fine there are four and each has 2 18" round bulbs in each one,any ideas appreciated
justgurn
Reg. Oct 2010
Posted 2014-03-03 10:48 AM (#157799 - in reply to #157797)
Subject: RE: Trailer Interior Light
Fluorescent lights have ballasts and diodes that might be causing your issue.
beeoerdog
Reg. Jan 2014
Posted 2014-03-03 11:29 AM (#157801 - in reply to #157797)
10010010010025
A little more info....Did they ever work? are they 12v and not 120v? Do you have a battery( not the breakaway battery )? Is the battery charged? Did they used to work with the truck connected? With all four not working, I would suspect a voltage supply problem. Post a little more info.
mulerider01
Reg. Aug 2012
Posted 2014-03-03 12:07 PM (#157802 - in reply to #157797)
They was working fine,we have the converter and the 2 battery set up and they won't work when hooked to 110 or just 12 volt, the switch is on a 3 way switch plate and the other 2 lights,porch and dinette lights both work fine,IF you have one bulb bad will it keep all the others that are even not in same fixture from working,i think I remember replacing one of the bulbs a couple years ago and the rest still was working,this is a very nice Hart lq trailer.......
mulerider01
Reg. Aug 2012
Posted 2014-03-03 12:09 PM (#157803 - in reply to #157801)
Maybe go ahead and replace ALL the 12 volt fuses in panel ,might be a cheap fix that I just can't see the one that's bad,but I figured ,the ceiling light and dinnett and porch light would be on the same one.
beeoerdog
Reg. Jan 2014
Posted 2014-03-03 12:32 PM (#157804 - in reply to #157797)
10010010010025
Hi
Sounds like the fixtures are 12v. It would be very unusual to have all of the bulbs powered by a single ballast so I get back to a voltage supply problem. Since the other lights are working properly, it sounds like you have voltage to the switch area. The switch that turns on the fluorescent lights could be bad. Take off the cover and see if you are getting 12v to the switch and coming out of the switch when it is turned on. ( use a test light...hook up clip to ground and use pointed probe to wire ) If test light lights up when switch is turned on, there could be a loose wire nut at the first fixture.
I have had those switches go bad with three fl. fixtures on them. They generally can't take the amperage required for that many fixtures. I have replaced that type of fixture with LED type and they work great.
If you find 12v at the fixture, it is possible that the ballast is burned out....switches starting to go bad can cause that problem. It would be unusual for all four to go bad at the same time but is possible.
First things first...check for voltage at switch and coming out of switch when it is turned on. You can pick up an automotive test light just about anywhere....Sears, Pep Boys,Napa...probe point to wire, ground clip to any clean(unpainted) part of the metal frame. If you check for voltage at fixture, clip to one wire and probe to other.
Try all of above and report back.
beeoerdog
Reg. Jan 2014
Posted 2014-03-03 12:53 PM (#157805 - in reply to #157797)
10010010010025
Don't go changing all the fuses...you can check them while they are in the panel.....just like the light switch with the test light...Attach clip to ground (could be a bus bar with a lot of white wires attached) and pointed end to each fuse contact point. A bad fuse will have only one side of the fuse lighting up the test light.
Holler back when you make progress
mulerider01
Reg. Aug 2012
Posted 2014-03-04 8:13 AM (#157821 - in reply to #157805)
Thanks so much will get on it soon as I can.
mulerider01
Reg. Aug 2012
Posted 2014-03-04 1:35 PM (#157825 - in reply to #157821)
Got er fixed,it was in the switch,thanks beeordog..........
beeoerdog
Reg. Jan 2014
Posted 2014-03-04 2:01 PM (#157826 - in reply to #157797)
10010010010025
Good job....it always feels good to solve a problem
