Finding a replacement gray water tank?
Last activity 2014-02-27 3:08 PM
4 replies, 4180 views
paysonw
Reg. Aug 2010
Posted 2014-02-26 2:17 PM (#157712)
Subject: Finding a replacement gray water tank?
I have worked with two different trailer repair shops/dealerships to find a gray water tank. We have been chasing this for almost a year now with no success. The tank was repaired once and that lasted a season but I think it should be replaced. This is for a 2003 CM horse trailer so I did not expect it to be so difficult to find a tank with similar measurements. Any suggestions would be appreciated!
kooner
Reg. Jun 2011
Posted 2014-02-26 4:18 PM (#157714 - in reply to #157712)
Subject: RE: Finding a replacement gray water tank?
a friend of mine was in the same situation and he went to a local shop and they made him one out of aluminum, he is happy with it and now he does not worry about rocks and the such going down gravel roads.
trailerconsult1
Reg. Mar 2009
Posted 2014-02-26 4:28 PM (#157715 - in reply to #157712)
Paysonw,
Call Cherokee trailers in OKC - they do their own LQ's and will sell you one and ship it to you
Posted 2014-02-26 10:00 PM (#157719 - in reply to #157712)
If you browse the Internet, you will find several suppliers of RV waste water tanks. They are available in many sizes, and if you have to, can be custom ordered as to where inlet and outlets are located. Usually two materials are available, ABS and polypropylene. The ABS is very easy to modify and repair if necessary; the poly has to be "welded" to afford the best attachments' strength.
paysonw
Reg. Aug 2010
Posted 2014-02-27 3:08 PM (#157724 - in reply to #157712)
Thank you for all the suggestions!
