Onan generator and a/c question
Last activity 2014-02-26 1:11 PM
7 replies, 4496 views
joskt0204
Reg. Aug 2012
Posted 2014-02-25 12:04 PM (#157669)
Subject: Onan generator and a/c question
Someone just offered my husband an Onan generator pretty cheap.  It's 27 amps, has about 250 hours.   Says 1800 rmp, 6.5 kW.  MOdel #6.5 NHD-FB/1M.
My trailer is just a little weekender, but I have a 13,500 a/c that I just had put on top in September.
Will this generator run it?
trailerconsult1
Reg. Mar 2009
Posted 2014-02-25 1:06 PM (#157670 - in reply to #157669)
Subject: RE: Onan generator and a/c question
Yes - Most definitely!
Posted 2014-02-25 4:16 PM (#157680 - in reply to #157669)
Without a problem
Spin Doctor
Reg. Nov 2008
Posted 2014-02-25 4:23 PM (#157681 - in reply to #157669)
And you might have friends at the camp site or rodeo as that should run another trailer or two.
Good luck!
joskt0204
Reg. Aug 2012
Posted 2014-02-25 4:27 PM (#157682 - in reply to #157669)
Cool!  Thanks.
flyinghfarm
Posted 2014-02-25 10:22 PM (#157692 - in reply to #157669)
1000100100
Oh yeah, you will be in great shape!!! and can run the microwave too!
justgurn
Reg. Oct 2010
Posted 2014-02-26 10:02 AM (#157701 - in reply to #157669)
This is a commercial generator. It is a 120/240V unit which is pretty cool but you likely won’t need 240V unless you want an oven or a welder. The 27 amps you stated is on the 240 side, at 120V you have 54 amps to play with. More than enough as others have said. From the size of your A/C unit you will need a 20 amp circuit to handle the startup and running. Also it is not a self contained unit so plan on some additional costs for mounting, battery, fuel and hard wiring.
joskt0204
Reg. Aug 2012
Posted 2014-02-26 1:11 PM (#157708 - in reply to #157669)
Wow - thanks for the extra info.  We are obviously newbies to the whole idea.  TY!
