2005 bloomer living quarter
Last activity 2014-02-04 4:49 PM
2 replies, 4507 views
ashlandmo
Reg. Dec 2010
Posted 2014-02-04 2:32 PM (#157340)
Subject: 2005 bloomer living quarter
I was wondering if anyone had an opinion on the 2005 Bloomers. 12ft short wall, pod, full lq, etc. I have had some friends that had problems with tires blowing. This trailer also has 7200# axles. Are these big enough?
Spin Doctor
Reg. Nov 2008
Posted 2014-02-04 4:09 PM (#157342 - in reply to #157340)
Subject: RE: 2005 bloomer living quarter
You are probably seeing the results of running 90-100% or more of axle capacity. The torsion axles are not designed to be at max carrying capacity most of the time. Is it a 3, 4, or 5 horse? Age and tire wear is a killer. New tires, will hold, but get 3 years on the G614s and a few miles, you will blow things up.
Ours is a Cimarron 4 horse with 12 LQ and will come in completely full at 18,800 pds. If you do the math, with 15% on tongue, each axle has to carry 7990.
I suggest running it over a scale and doing the math. My experience is that I want to run no more than 75% of axle capacity. Good luck!
kooner
Reg. Jun 2011
Posted 2014-02-04 4:49 PM (#157343 - in reply to #157340)
8000# axels and 17.5 wheels will cure a lot of problems. we have a 4 horse C & C hay pod generator and 15 LQ with no problems.
