Looking for Corner Post Insulators
Last activity 2014-05-01 2:09 PM
9 replies, 9401 views
jdzaharia
Reg. Apr 2006
Posted 2014-01-31 8:30 AM (#157260)
Subject: Looking for Corner Post Insulators
1001001001002525
I am looking for corner post insulators similar to the photo I have shown, except I have steel pipe corners and braces, not wood.  So, instead of a lag bolt style screwing into a wood post, I will drill through the steel pipe post.  I need the rod threaded to accept a washer and nut on the back side.  I cannot find anything made specifically for my purpose.  I can buy the donut style insulators, but I am not sure where to source the rod.  Does anybody have any ideas as to what I could use?
Posted 2014-01-31 11:06 PM (#157271 - in reply to #157260)
Subject: RE: Looking for Corner Post Insulators
Check Tractor Supply. The have insulators for metal posts that will work on corner installations.
cajunmuleman
Reg. Oct 2011
Posted 2014-02-01 7:30 AM (#157273 - in reply to #157260)
Look at the big box stores in the electrical department for something like this one. This is from Home Depot but they all have them for standard electrical useHalex 1-1/4 in. - 3 in. Adjustable Wire Holder Model # 60525 Internet # 100162693 Store SKU # 140503
Marla
Reg. Mar 2008
Posted 2014-02-01 10:43 AM (#157276 - in reply to #157260)
500
Anyone with a torch can cut and bend all thread to any dimensions you need.
jdzaharia
Reg. Apr 2006
Posted 2014-02-02 12:08 AM (#157287 - in reply to #157260)
1001001001002525
I have not seen anything at TSC, either in store or online that is made for round steel posts. If gard or anybody has a link or description I would be interested..The insulator from Home Depot is on the right track. I am using Electrobraid fence, so I think a roller would be best. I am not sure if the rope will slide around that glass well enough. I might go look at that in person..I thought about bending all thread into the shape I need, but my experience with all thread odds that it bends tip easily to keep its shape. I'm not sure the tension of the fence won't just deform the shape I want.
Edited by jdzaharia 2014-02-02 12:10 AM
jdzaharia
Reg. Apr 2006
Posted 2014-02-07 1:11 PM (#157374 - in reply to #157260)
1001001001002525
Found these, but they are kind of pricey, and the smallest I can find them is 1/2-inch bolt diameter, which is a bigger hole than I was hoping to have to drill.
Edited by jdzaharia 2014-02-07 1:15 PM
Posted 2014-02-08 8:49 AM (#157379 - in reply to #157260)
Eye bolts are available in many diameters and lengths. It would be an easy matter to heat the end of the ring and open it into an "L" shape. Some basic post bending heat treatments, would make the metal rod rigid enough to prevent most normal deformities.
jdzaharia
Reg. Apr 2006
Posted 2014-03-31 11:25 AM (#158350 - in reply to #157260)
1001001001002525
I figured I would update this thread. I ended up going with Electrobraid's corner post insulators. I just used some #12 Tek5 self-tapping screws to attach them to the steel pipe posts. They bore the existing hole in the plastic insulator a little bigger, but they seem to be really sturdy insulators.
Edited by jdzaharia 2014-03-31 11:27 AM
warreng5995
Reg. Apr 2014
Posted 2014-04-29 8:59 PM (#158860 - in reply to #158350)
Hi! Just found this site while searching for a solution to my fencing problem. I'm in the same situation. I also have steel corner and brace posts. I have been searching for a solution just like what you came up with, a simple screw in corner insulator. The only thing is, I need it for 14 gauge smooth aluminum fence wire, and I think your solution is only rated for electric rope. Does anyone know of a company that makes something like this, except for wire fencing? Thanks
jdzaharia
Reg. Apr 2006
Posted 2014-05-01 2:09 PM (#158897 - in reply to #157260)
1001001001002525
If you are just using regular smooth wire, I would think those Electrobraid insulators would work. I would not use them with high-tensile wire, though.
