Stall mats
Last activity 2014-02-06 10:15 AM
7 replies, 5833 views
Kwarren
Reg. Jan 2011
Posted 2014-01-27 6:26 PM (#157201)
Subject: Stall mats
Any of you use mats in your stalls if so what kind and how did you prepare the surface underneath.
skippyvcu
Reg. May 2006
Posted 2014-01-27 7:49 PM (#157207 - in reply to #157201)
Subject: RE: Stall mats
We use mats that are about 3/4 of an inch thick. Thinner mats won't lay flat. The key is the surface preparation to get a level surface. In ours we used crusher run to create a level surface and then a 2 inch layer of gravel dust. In our area crusher run is mostly granite dust with some crushed granite gravel. It provides a solid base when compacted with a plate compactor. The gravel dust is granite dust from the crushing process with no gravel. It packs almost like concrete when compacted and is easier to level.
You can cut the mats easier by bending them over a 2X4 and using a snap blade knife.
PDGx
Reg. Jul 2011
Posted 2014-01-27 7:56 PM (#157210 - in reply to #157201)
I use the rubber mats from TSC. They are on a concrete floor - sloped toward a drain - (but I should have doubled the slope). We use sawdust for bedding on top of them. They have held up very well. I cut them with a circular saw.
Edited by PDGx 2014-01-27 7:58 PM
Posted 2014-01-27 10:50 PM (#157211 - in reply to #157201)
http://www.youtube.com/watch?v=-HxbInDi5O0
bjhouten
Posted 2014-01-28 12:44 PM (#157221 - in reply to #157201)
5002525
I got the interlocking mats from Tractor Supply. You have to special order them. LOVE THEM!
Posted 2014-01-28 10:13 PM (#157230 - in reply to #157201)
1000500100100100252525
I use rubber mate over fine crushed stone ( idem 4) that way the urine go thought
mudassar1
Reg. Feb 2014
Posted 2014-02-04 1:39 AM (#157335 - in reply to #157201)
What do you all think of stall mats? I keep going back and forth on them.In my barn, we installed one stall with mats, the others are still dirt floor.Well, I don't think I care much for the matted one. I use shavings for bedding, as much as I would with a dirt floor. But the urine still collects in the middle, the surface stays wettish looking after a thorough cleaning, and frankly, it still stinks all the time. The smell is different than in the dirt stalls, kinda funky and rubbery
Posted 2014-02-06 10:15 AM (#157360 - in reply to #157201)
I like rubber mat as far as the smell you could use ag lime or there is other stuff you could put in the stall to control the smell
