If I could junk my Generac 3600 watt Generator, what should I replace it with?
Last activity 2014-01-01 2:38 AM
4 replies, 4718 views
agfckrowe
Reg. Jun 2009
Posted 2013-12-29 3:12 PM (#156467)
Subject: If I could junk my Generac 3600 watt Generator, what should I replace it with?
If I could scrape up the money to replace our LQ roof mounted Generac QuietPac 40G generator, what should I replace it with that will give the power we need and be reliable and not the broken down mess the Generac is? We have a 2005 Platinum 3 H 8 ft shortwall with large fridge, shower, propane heat AC.
Posted 2013-12-29 3:49 PM (#156471 - in reply to #156467)
Subject: RE: If I could junk my Generac 3600 watt Generator, what should I replace it with?
http://www.yamahagenerators.com/EF3000iS-p/ef3000is.htm
http://www.yamahagenerators.com/EF3000iSEB-p/ef3000iseb.htm
agfckrowe
Reg. Jun 2009
Posted 2013-12-29 4:03 PM (#156473 - in reply to #156471)
Is there a Honda or Yamaha RV generator that I can put on the roof and hook up like my Generac so I can just start it with a push of a button from inside the LQ? Or am I missing the benefits of a portable generator that my husband may abscond with for other jobs?Is 3000 watt sufficient to run the AC and a hair dryer?When our electricity goes out, which it does fairly frequently in our rural location, we used to must move into the LQ trailer - back in the good ole days when the Generac worked.
justgurn
Reg. Oct 2010
Posted 2013-12-29 8:18 PM (#156483 - in reply to #156467)
I would replace it with a Onan 4.0 Micro Quiet. Several places on the web or ebay to buy one. You will need a new controller in the house too. More $$. Good luck! Jg
poco5
Reg. May 2006
Posted 2014-01-01 2:38 AM (#156558 - in reply to #156467)
I know several people who have a Honda 3000 mounted in the hay rack on the roof with a remote starter.We haul our Honda in the tack compartment and unload it to use for the trailer.We have a transfer switch in the house and plug the generator in when the power goes out.It runs the fridge ,furnace , lights , TV ,etc. You just have to remember not to run things like the microwave and coffee maker at the same time as they require several watts.
