Grease on the brakes
Last activity 2013-10-25 1:25 PM
4 replies, 3886 views
Ncatanz
Reg. Jun 2008
Posted 2013-10-23 11:38 AM (#155493)
Subject: Grease on the brakes
While getting my trailer inspected I was told that the last person to grease and pack the bearings got grease on the brakes and now the brakes and the magnets all need replaced.  Can that much damage to done by just some grease?
Posted 2013-10-23 11:54 AM (#155495 - in reply to #155493)
Subject: RE: Grease on the brakes
The magnets can be cleaned. The brake shoes can attempted to be degreased with an aerosol cleaner, but usually it is a waste of time. New shoes and a proper cleaning of the hubs will ensure a properly operating system.
Posted 2013-10-23 5:53 PM (#155498 - in reply to #155493)
Had a truck mechanic tell me if you don't replace the pads and have the down time available then clean them with brake cleaner, then let them dry, then take your oxyacetylene torch and pass it back and forth over the pads to cook out any grease embedded in the pads. After they cool off clean them again with brake cleaner. No warranty offered, as I have not had to do this yet...
Edited by PaulChristenson 2013-10-23 5:54 PM
Spooler
Reg. Aug 2006
Posted 2013-10-24 12:21 AM (#155501 - in reply to #155493)
50025
The seal probably failed causing the grease to go everywhere. That's one issue with hubs with zerk fittings. Folks will push too much grease in them
and the inner seal will fail.
bigfoot
Reg. Dec 2010
Posted 2013-10-25 1:25 PM (#155539 - in reply to #155493)
I recently had my bearings packed.  The guy got a little slap happy.  I sanded the pads with 220.  Then passed a torch over them.  It took longer to fix, than it would have taken me to pack them to begin with.
