Changing permanent tack to collapsible
Last activity 2013-12-28 10:26 AM
4 replies, 5760 views
Nurse Pepsi
Reg. May 2012
Posted 2013-10-19 9:53 PM (#155442)
Subject: Changing permanent tack to collapsible
Has anyone ever changed a permanent tack to collapsible? It's a 4 Star trailer. The center divider bar is welded, walls are bolted at the bottom.Thanks, Nurse Pepsi
terri s
Posted 2013-10-20 8:48 AM (#155444 - in reply to #155442)
Subject: RE: Changing permanent tack to collapsible
500100100100
I had to chuckle simply because I am starting to think about a newer trailer and I can't find any with the fixed tack!
Arieldouglas
Reg. Aug 2013
Posted 2013-10-20 9:36 AM (#155445 - in reply to #155444)
Really? Now that shows the difference between people. Two things that mak a trailer a non-starter for me is a fixed tack and the door to th LQ on the driver side. I'm sure it could be done but would require some skill with cutting welding. If it is an aluminum trailer them the skill level goes up for DIY person. Then also consider the trailer itself. Is the tack fixed in place because it is a structural part othe rear end and is the wall stout enough to hold the weight of tack wall without racking the back doors? Just things to think about. It might need to be looked at by a professional unless you are confident in your abilities. Maybe time to trade?
RTSmith
Posted 2013-10-21 8:22 AM (#155454 - in reply to #155442)
We've done several over the years. I don't recall ever seeing one that was a structural component of the trailer.
The trick to hold costs down is to try and reuse as much of the existing equipment as you can. You'll cut it loose, and modify it to move/fold. Each is different, but usually no challenge for any aluminum fabricator. You'll typically need to add some semi-specialty hardware like is used in the folding designs to achieve your desired results.
RTSmith
www.SelectTrailer.com
ellisor
Reg. Oct 2010
Posted 2013-12-28 10:26 AM (#156447 - in reply to #155442)
RTSmith, I know labor and material cost will vary, but could you give a WAG on the cost of converting to a folding/removable tack?
