2000 Silverado, AC unit questions
Last activity 2013-10-08 8:36 AM
8 replies, 4669 views
Redreiner47
Reg. Aug 2013
Posted 2013-10-07 11:53 AM (#155207)
Subject: 2000 Silverado, AC unit questions
I have a a 2000 silverado with the Roper LQ , very small lq , the AC unit is a coleman mach II and it worked just fine last time I plugged the trailer in and turned it on. Getting ready for a trip so was checking everything... and this time ABSOLUTELY nothing happens when I turn it on, trailer is plugged in, checked fuse panel and circuit breakers, all are good and flipped to on, none of the breakers say AC unit, just main and furnace etc. flipped them all anyway, still nothing. is there another box somewhere? a fuse inline somewhere that I dont know about? trailer is not level if that matters, its parking spot is slanted if that makes a difference. any help?? suggestions? RV place close to me does not touch AC units...
Bhill
Reg. May 2013
Posted 2013-10-07 12:30 PM (#155208 - in reply to #155207)
Subject: RE: 2000 Silverado, AC unit questions
Can you determine if the switch/thermostat is working properly? Please see this pdf file for other information.>>>>>>>>>http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Redreiner47
Reg. Aug 2013
Posted 2013-10-07 12:54 PM (#155209 - in reply to #155207)
Thanks Bookmarked that for the other half to look at. am just making sure there is only one fuse box in this trailer and I am not over looking something simple. I have to assume the AC is wired to the Main breaker as it does not have its own.
horsey1
Reg. Dec 2004
Posted 2013-10-07 1:04 PM (#155210 - in reply to #155207)
If it isn't doing anything, and does have power. Take the top cover off, and spin the fan blade by hand. It is common for the motor to seize if it sits. Once it starts to spin, oil the bearing and it will run a while longer. 10 minutes, or 10 years....
Posted 2013-10-07 3:43 PM (#155211 - in reply to #155209)
Most AC units will have a dedicated A/C circuit with its own breaker. Usually they are 15 - 20 Amps in the smaller and mid sized ratings. I would check the breakers with a VOM to make sure they are in fact working. Just flipping them on and off won't guaranty that they are reset.
If the fan's motor is frozen, usually you will hear a humming or metallic buzzing sound for a short time until the breaker pops. When the opperating switch is selected, you should hear some mechanical sounds. If nothing is occurring, I would suspect a lack of power to the unit.
Redreiner47
Reg. Aug 2013
Posted 2013-10-07 11:33 PM (#155213 - in reply to #155211)
Originally written by gard on 2013-10-07 1:43 PM
exactly, nothing happens, as if there is no power, all of the fuses are good, none of the breaker switches were flipped to off. bugger... taking off friday and although I wont need the AC its still something I would like fixed. strange how it worked and then didnt just like that.
cajunmuleman
Reg. Oct 2011
Posted 2013-10-08 6:41 AM (#155216 - in reply to #155207)
If the fan nor compressor are running than it is one  three things. Either no power to the unit, a bad selector switch/thermostat, or bad dual run capacitor.
yeehaw
Posted 2013-10-08 8:22 AM (#155218 - in reply to #155207)
possible loose connection and/or burnt connection or wire, the system will need to be opened and checked for the problem to be ID'd
cajunmuleman
Reg. Oct 2011
Posted 2013-10-08 8:36 AM (#155219 - in reply to #155207)
You are also correct, I didn't mention a broken wire or bad connection
