New awning and blocked my trailer
Last activity 2013-09-27 3:16 PM
8 replies, 5289 views
bjhouten
Posted 2013-09-25 5:20 PM (#154960)
Subject: New awning and blocked my trailer
5002525
I got my new awning installed, 20 feet long. I also had my trailer blocked so it would not sit high in front. That meant that we had to lower the neck so it would sit level. Now it looks good, sits level, but I don't have enough room between my truck bed rails and trailer to make some steep turns, like the one to get into my neighborhood. (I can go the long way around.) I guess there is no getting ahead. LoL. Let's see if my picture posts....
paysonw
Reg. Aug 2010
Posted 2013-09-25 6:48 PM (#154961 - in reply to #154960)
Subject: RE: New awning and blocked my trailer
How much did you block it? 2 or 3"?
Thanks!
yeehaw
Posted 2013-09-25 7:05 PM (#154962 - in reply to #154960)
WOW, that looks really close to ya truck bed rails...good luck
Linda Y
Reg. May 2007
Posted 2013-09-26 8:56 AM (#154973 - in reply to #154960)
10010010025
Wow, what do you do in a case like that...you can't lower the truck. Raise the whole trailer more??
bjhouten
Posted 2013-09-26 1:05 PM (#154974 - in reply to #154960)
5002525
It was a 3" block. Talked to service department today and they said to go ahead an raise the neck. Can't go up anymore, and truck can't (or I won't do that) come down.
paysonw
Reg. Aug 2010
Posted 2013-09-26 3:54 PM (#154976 - in reply to #154974)
Thanks for the info!  You may want to try the B&W tube or some of the others that have a shock/rubber block in them, they may be taller than the one you have.  the trailer looks level in the photo.  I thought that there should be a slight slant to the rear when loaded.
Posted 2013-09-27 10:14 AM (#154984 - in reply to #154974)
Originally written by bjhouten on 2013-09-26 10:05 AM
Did you cut the hitch tube?  I would raise the hitch a bit.  Try 2 inches... I like to have the trailer nose just a bit higher than level.  It allows the urine and rain to flow toward the back of the trailer.
bjhouten
Posted 2013-09-27 12:48 PM (#154992 - in reply to #154960)
5002525
I went out and raised it a hole this morning. The holes are on about 2.5" centers. It actually looks really good. Lots of room from bed rails and just a slight slant. I'm happy with the results. I won't be dragging the bottom of this trailer! Now I just have to get the A/C fixed that just broke. The fan seems to be stuck. LoL.
bjhouten
Posted 2013-09-27 3:16 PM (#154995 - in reply to #154960)
5002525
I think my posting might have confused some people. I did/do have room to take my trailer neck up and down. I meant that I could not block the trailer up anymore, and that I not interested in having my truck lowered. It sits fine now. So I'm good to go.
