Roof AC/heat units power necessities? AC vs heat?
Last activity 2013-08-26 10:34 AM
3 replies, 4696 views
horsesnharleys
Reg. Apr 2011
Posted 2013-08-26 9:58 AM (#154275)
Subject: Roof AC/heat units power necessities? AC vs heat?
I am new to the whole living quarters world. We recently bought a trailer with a little weekend package. it on;y has a roof AC/heat, and lights with a plug in on the outside of the trailer for electrical power. I am trying to learn what I need (ie generator, power hook up, battery, propane) to run what I have and what I might want to add in the future. I have read several things about roof AC units needing a lot of power to run. I was told by friend that I would need a 5000watt generator to run AC if I also may want to run anything else at same time? Also read something saying I will need 30amp plug in order to run ac? Does the heat take the same power requirement as the AC if it is all one unit? Thanks
hogtownboss
Posted 2013-08-26 10:20 AM (#154276 - in reply to #154275)
Subject: RE: Roof AC/heat units power necessities? AC vs heat?
10001001001002525
A 3000 watt generator will work just find for what you are wanting.....
The heat strips in the roof a/c systems are worthless and even worse if you live in cold locations.  All we ever use is a small portable electric heater in our 10' living quarters and it works great!  Have never even turned the factory installed heater on.
Edited by hogtownboss 2013-08-26 10:22 AM
horsesnharleys
Reg. Apr 2011
Posted 2013-08-26 10:26 AM (#154277 - in reply to #154275)
to run a small space heater do you need a power plug in, or generator or can a battery system power it?
paysonw
Reg. Aug 2010
Posted 2013-08-26 10:34 AM (#154278 - in reply to #154277)
Originally written by horsesnharleys on 2013-08-26 10:26 AM
We use a 2,000 watt Honda generator to run our space heater if we can't plug in. We hook them up in tandem (4,000 watt to run the air in either of our LQ trailers if no plug in is available. 3,000 should be enough to run most rooftop AC units unless you are way up in the mountains then 4,000 would be better.
