Trailer Leaks
Last activity 2013-08-19 6:24 PM
13 replies, 8295 views
Gone
Posted 2013-08-14 8:38 AM (#153998)
Subject: Trailer Leaks
10002525
Hubby and I have been really busy this year and we kept saying we need to get our 2006 trailer in for roof maintenance. Well, the trailer has been sitting unused for awhile. I went to clean it and saw mushrooms growing from the wall by the floor under the table. Also, found a mushy spot on the wall and floor under the bathroom cabinet. I freaked! We pulled back the flooring and put fans on the areas and ran the air until they dried out. I made an appointment for the roof and had it fixed. We have had several down pours since and both areas were bone dry. Now we have to fix the areas, hubby says he has to cut them out etc. He is confident in doing this. I am glad the leaks have stopped but when we saw the leaks I remembered someone on this forum saying to not let your trailer go longer than 5 years for the roof. I think it was Gard but not sure. We will take it in annually to have it checked from now on, lesson well learned!!!! I thank this forum for being so informative!
Edited by Gone 2013-08-14 8:40 AM
diamondweedo
Reg. Jul 2013
Posted 2013-08-14 1:19 PM (#154001 - in reply to #153998)
Subject: RE: Trailer Leaks
What did you use to repair the leaks in the roof ?
Spooler
Reg. Aug 2006
Posted 2013-08-14 4:04 PM (#154003 - in reply to #153998)
50025
I just went through something similar. I noticed a leak in the horse area. My trailer was leaking at the screws that go into the supports. It took a day of cleaning and I re caulked those screws on the whole roof. My pinch rail needs to be redone also. Mine is an 06' as well. The next day that is going to be good weather the pinch rail will be re- caulked also. My skylight over the shower is showing it's age, I will be replacing it also. I re-calked it several years ago when it started looking bad. I am using Dap Silicone II extra flexible as a replacement. I am also getting tired of the major cleaning I have to do each year because the trailer sits outside. I just spent 2 days cleaning the black streaks, washing the roof, and brightening the aluminum. All I have left in that department is a wash and wax. I have help with that part, traded the labor for hauling the sister in-laws new horse home. Boy I sure do need the help in the labor department...LOL
I normally inspect the roof once a year looking for any issues. I just grab the ladder and take a peak. It's easy to do and after all the fun I had when I first bought the trailer, I learned my lesson. Thanks to Don at Dixie Horse & Mule.
Edited by Spooler 2013-08-14 4:08 PM
Weekender
Reg. Aug 2013
Posted 2013-08-16 1:16 PM (#154051 - in reply to #153998)
I am looking at buying a new trailer. I wonder if there is a specific brand that will tend to leak more than others or what should I look for to help reduce this common problem?Thanks.
Bhill
Reg. May 2013
Posted 2013-08-17 5:22 AM (#154063 - in reply to #154001)
Originally written by diamondweedo on 2013-08-14 1:19 PM
Look for Silkaflex Sealant this is what RV repair shops use. With all due respect DAP Silicone doesnt cut it.
Gone
Posted 2013-08-17 8:13 AM (#154065 - in reply to #154001)
10002525
We took it in at a local rev place. Didn't ask what they used.
jim bob
Reg. Jan 2008
Posted 2013-08-17 8:26 AM (#154066 - in reply to #153998)
Most every manufacturer of aluminum horse trailers uses a one piece aluminum roof that is attached to the roof radius pieces (rounded piece that attaches wall to roof); these are rivieted to the roof skin.  The seam is than sealed with a roof sealant.  The only company that I can think of that doesn't do their roofs that way is Eby.  Since they use an aluminum I-beam roof rail; their roof skin has no seams in it whatsoever.  It is riveted to the outside flange of the roof rail.  Hart and Cimmaron are two companies that don't use aluminum skin for their roofs.
Bhill
Reg. May 2013
Posted 2013-08-17 9:06 AM (#154067 - in reply to #154063)
Originally written by Bhill on 2013-08-17 5:22 AM
Sikaflex 715 is what is recommended for RV applications.
Posted 2013-08-17 9:41 AM (#154068 - in reply to #153998)
Sikaflex caulk has been used twice on my 1999 trailer.  Once by Sundowner and once by me.  Seems like the caulk on the roof/rail seam lasts about 6 years. And My trailer is under shelter when not in use!
This year I'm trying something different.  Eterna bond roof tape.  After removing the existing caulk with a wire cup brush in a side grinder, 2 inch wide tape was applied over the seam & rivet heads.  I used a caster wheel to press the tape on.  Rolling the tape applied more pressure than hand alone.  (easy on the hand too) The tape was a lot easier to handle and apply than the caulk.  LESS MESS.
If I had it to do over, I would have used 3 inch tape.  Not so critical in placement to cover the rivet heads & seam.
I'll see how long this lasts... Eterna bond says 15 years!
Bhill
Reg. May 2013
Posted 2013-08-17 10:23 AM (#154069 - in reply to #154068)
.....This year I'm trying something different.  Eterna bond roof tape.  After removing the existing caulk with a wire cup brush in a side grinder, 2 inch wide tape was applied over the seam & rivet heads.  I used a caster wheel to press the tape on.  Rolling the tape applied more pressure than hand alone.  (easy on the hand too) The tape was a lot easier to handle and apply than the caulk.  LESS MESS.
>>>> You wont be disappointed with Eterna Bond tape- I have done many trailers and campers with this tape- I have patched awnings with this stuff... It is better than sliced bread....
Spooler
Reg. Aug 2006
Posted 2013-08-18 8:36 PM (#154097 - in reply to #154067)
50025
Originally written by Bhill on 2013-08-17 1:06 PM
Where can I get it? I still have more work to do.
Posted 2013-08-19 11:03 AM (#154108 - in reply to #154097)
Originally written by Spooler on 2013-08-18 5:36 PM
If you insist on Sikaflex ... Call your local roofing supply  or use this link to find a distributor & local dealer.
http://usa.sika.com/en/system/locators/main_distributor.html
Edited by hosspuller 2013-08-19 11:04 AM
Bhill
Reg. May 2013
Posted 2013-08-19 11:13 AM (#154110 - in reply to #154097)
Originally written by Spooler on 2013-08-18 8:36 PM
Try Tweety's online- Great Service..>>>>>>>>>>>http://tweetys.com/caulking.aspx?page=2
Spooler
Reg. Aug 2006
Posted 2013-08-19 6:24 PM (#154121 - in reply to #153998)
50025
I insist on using something that will last and do a good job. Whenever it stops raining I will finish the job.
