Is 18750 to much for a F350 SRW ??
Last activity 2013-06-18 5:26 PM
9 replies, 5671 views
Bhill
Reg. May 2013
Posted 2013-06-16 9:27 AM (#152788)
Subject: Is 18750 to much for a F350 SRW ??
We are struggling trying to find the actual weight of a 2005 S/D 8013+2 3 Horse trailer. Our F350 is rated at 15900 towing with 4010 cargo carrying capacity.Is this trailer to heavy for a 2011 F350 SRW 6.7l ??
Edited by Bhill 2013-06-16 9:28 AM
CTRider
Reg. Sep 2009
Posted 2013-06-16 9:43 AM (#152789 - in reply to #152788)
Subject: RE: Is 18750 to much for a F350 SRW ??
10010010025
You dont really state what the trailer is. 05 Sundowner, correct? 3 horse slant? Is it a full LQ, weekender, dressing room only??? What length is the short wall?
Bhill
Reg. May 2013
Posted 2013-06-16 9:49 AM (#152790 - in reply to #152789)
Originally written by CTRider on 2013-06-16 9:43 AM
Yes it is a 2005 Sundowner Sierra Model 8013 plus 2 - (15 foot shortwall) 3 horse slant.Thank you
PDGx
Reg. Jul 2011
Posted 2013-06-16 10:44 AM (#152794 - in reply to #152788)
Lots of opinions here I bet. My opinion only. 18750 sounds a bit much for a SRW truck. Our horse trailer is a 7' Short wall, but with one more slant stall. Don't know exactly what it weighs, but it's considerably less than what I pull on our flatbed. We also pull a 35' 5th wheeler RV that also weighs more than the horse trailer. I have legally maxed truck/trailer weights with our flatbed which is about what you are estimating for your trailer. About 15 years ago I had to go to a DRW for stability / safety. The SRW was getting a bit squirrelly especially when braking. The DRW brought it under control, and gave an added measure of safety with the extra tires. As far as pulling 18750 - probably can. But keeping it under control - marginal at best - in my opinion.
Bhill
Reg. May 2013
Posted 2013-06-16 12:37 PM (#152797 - in reply to #152794)
We found out the trailer weighs about 12,200. So that leaves us with only 3,700 lbs- for horses, water, fuel,feed, food (no ramen allowed) and tack, in order remain under the trucks rating of 15,900. We would be a nervous wreck trying to be safe for the horses.
Posted 2013-06-16 4:28 PM (#152798 - in reply to #152788)
Yes
Bhill
Reg. May 2013
Posted 2013-06-16 4:30 PM (#152799 - in reply to #152798)
Originally written by PaulChristenson on 2013-06-16 4:28 PM
Yes
Thank you
Posted 2013-06-16 6:46 PM (#152803 - in reply to #152788)
Originally written by Bhill on 2013-06-16 9:27 AM
Your gross combined weight rating is somewhere around 23000#... Your truck will probably weigh in at 8500# or better empty? Figure that trailer weight with three horses and a weeks worth of STUFF... It adds up in a hurry!!!
hornet
Posted 2013-06-16 8:10 PM (#152807 - in reply to #152803)
Sounds like too much trailer for your truck. Our trailer weights 12,000 pounds empty and we pull it with a GMC 4500. Loaded the pin weight is 5,500 pounds and my GCVW is close to 29,000 pounds.
ROCKIN'TK DECATUR
Reg. Mar 2013
Posted 2013-06-18 5:26 PM (#152841 - in reply to #152788)
YES, sure would not do that unless you had dual wheels on the ground in the rear....  Mine is only an 8010 model 3 horse and I would not even try it with a single wheel truck. my trailer empty before anything is added is 9300lbs.
Edited by ROCKIN'TK DECATUR 2013-06-18 5:28 PM
