trailer tires
Last activity 2013-08-25 8:10 PM
24 replies, 13383 views
kooner
Reg. Jun 2011
Posted 2013-06-13 7:33 AM (#152689)
Subject: trailer tires
planning on putting Michlein LTX  235  85 16 E   tires on an LQ trailer has anyone had problems with this combo.?
Saddleup
Reg. Apr 2012
Posted 2013-06-13 7:36 AM (#152690 - in reply to #152689)
Subject: RE: trailer tires
Have these on my dodge ram and 16 ft stock trailer, very happy with the performance and wear pattern of these tires. Used on both highway and gravel roads.
RTSmith
Posted 2013-06-13 8:01 AM (#152692 - in reply to #152689)
The LTX is a nice tire, standard polyester/steel construction in an all-season tread (both the M/S and the A/T). If you can justify it, the XPS Rib is an all steel tire with a great tread pasttern for even wear on a trailer. It is the best choice Michelin has in a load range "E" for trailering.
jim bob
Reg. Jan 2008
Posted 2013-06-13 10:09 AM (#152698 - in reply to #152689)
I run these tires on my Sundowner LQ (3H 10' shortwall) and feel that they are very safe tires.  We have used this same tire on some of our customers trailers also.  Both the Michelins and the Good Year 10 and 14 ply tires are as good a trailer tire as there is available (in my opinion).
Posted 2013-06-13 3:14 PM (#152711 - in reply to #152689)
Originally written by kooner on 2013-06-13 7:33 AM
What are your axle ratings?? What's your trailer GVWR?
kooner
Reg. Jun 2011
Posted 2013-06-13 3:18 PM (#152712 - in reply to #152689)
7000 axels    16,000 gvw     it has 235   80 16 E  st Trail Masters  on it at the moment.
Posted 2013-06-13 4:38 PM (#152716 - in reply to #152689)
I would spend the extra bucks for a load range "G" tire... That is if your rims will support 3750# and or 110 psi air pressure...
http://www.goodyear.com/cfmx/web/truck/line.cfm?prodline=160007
Trailer tire and wheel mounted, aired up ready to go... http://www.easternmarine.com/goodyear-lt235-85r-16-radial-tire-sil-modular-rim-8-lug-lr-g
kooner
Reg. Jun 2011
Posted 2013-06-14 11:51 AM (#152743 - in reply to #152689)
I would like to go to a heavier tire and my rims are 3750 but 80 psi, while checking the price difference and freight it would cost another $1000 for 4 tires over the LTX Michlein  thanks all
Candy girl
Reg. Apr 2006
Posted 2013-06-14 12:20 PM (#152745 - in reply to #152689)
My Sundowner LQ with 12' shortwall and and mid-tack has G rated tires.  I'm looking to replace my tires too, but definitely sticking with G rated.
Posted 2013-06-14 2:40 PM (#152751 - in reply to #152743)
Originally written by kooner on 2013-06-14 11:51 AM
   Check the price difference between the LTX M/S and the XPS RIB... The XPS RIB in a LR-E will be about the same price as the Goodyear G614RST lr-G... I have a friend with a 5 horse SD that has been all over the country. He's running 7" aluminum wheels with 265-75R16 LR-E LTX M/S Michelins. I believe they are rated at 3415# at 80 psi each, never had a problem but he is running a 7 " wide wheel.
  I just like the strength of a all steel casing like that of the XPS RIB Michelin and the G614RST Goodyear.
   Good luck with your final decision.
Spin Doctor
Reg. Nov 2008
Posted 2013-06-17 11:36 AM (#152818 - in reply to #152689)
Agree with the remarks as to the Goodyears...blew the tread off of one at 75 mph, 85 degrees and 18,000 pounds. Tire never did go flat and still had 110 lbs of air after the 8 miles it took to get off the interstate. ~30% tread left i would guess before..probably was damaged sometime but I did just rotate them last weekend...hummmmm.....
I doubt any other tires would of still been inflated....
Posted 2013-06-17 8:16 PM (#152831 - in reply to #152818)
Originally written by Spin Doctor on 2013-06-17 11:36 AM
Agree with the remarks as to the Goodyears...blew the tread off of one at 75 mph, 85 degrees and 18,000 pounds. Tire never did go flat and still had 110 lbs of air after the 8 miles it took to get off the interstate. ~30% tread left i would guess before..probably was damaged sometime but I did just rotate them last weekend...hummmmm.....I doubt any other tires would of still been inflated....
What was the tire manufacture code on your Goodyears?
Posted 2013-06-17 11:28 PM (#152833 - in reply to #152689)
1000500100100100252525
I was looking at discover E rated tire for my trailer any thought on these
Posted 2013-06-18 12:01 AM (#152834 - in reply to #152833)
If you are referring to Cooper "Discovery" tires, in our part of PA, Cooper tires has a very good reputation for LT truck tires; long wearing, good handling, and many styles are available.
Cooper was recently purchased by an Indian company, Apollo Tyres. Don't know how this will affect the Cooper named products.
Posted 2013-06-18 9:47 PM (#152844 - in reply to #152689)
thank you for the information that is the company coopers
trot-on
Reg. Dec 2009
Posted 2013-08-04 7:53 PM (#153816 - in reply to #152689)
the new-to-me trailer we are getting seems to have the original tires on it from 2004. So, time to replace those too. I have to look what is on them, but I remember seeing load range G. (Sundowner, 3H, 14'LQ). . . . So I will be mentally prepared when I head in to buy them, about how much per tire will I roughly be spending??? .... I have always shopped at Discount Tire due to the road hazard, and being able to replace pretty much anywhere we go if something happens, they should have something in this size I assume???
Spooler
Reg. Aug 2006
Posted 2013-08-05 8:48 PM (#153846 - in reply to #152689)
50025
I am converting over to the Goodyear G614 tires here lately. 2 left to go. I just can't see throwing out an OK tire unless I was preparing for a long haul. The tires are quite pricey but my last 2 were about $350 a piece. First one over a year ago was over $400.
trot-on
Reg. Dec 2009
Posted 2013-08-05 11:08 PM (#153854 - in reply to #153846)
Originally written by Spooler on 2013-08-05 8:48 PM
Aw geez........ At least I am prepared now....These look good, but they are 9 years old, and all my hauls are at least 200 miles. Will have them keep the 2 best for spares. (I like to carry 2 spares on long hauls)
genebob
Reg. Nov 2007
Posted 2013-08-06 11:00 AM (#153865 - in reply to #152689)
I just put the last two G614's on for $325 each from my local mechanic. He sold the Larados that he took off for $100 each for me.
kigermom
Reg. Aug 2013
Posted 2013-08-18 9:24 PM (#154102 - in reply to #153865)
My trailer tires are due to be replaced. I would like to know what I should be looking for in brands/sizes. My current tires are HF-504, 7.50-16LT, DURO. There is a very small HFR near the word DURO - not sure if that means anything important. What I have doesn't look like anything I have read in the above postings. My trailer is a 2004 Exiss gooseneck, 3 horse slant with 8ft LQ. Any suggestions?
Spooler
Reg. Aug 2006
Posted 2013-08-19 12:41 AM (#154103 - in reply to #154102)
50025
Originally written by kigermom on 2013-08-18 1:24 AM
I would go with the Michelin's as stated above in a load range E. I don't think you would need the load range G.
tom-tom
Reg. Feb 2008
Posted 2013-08-20 7:40 AM (#154138 - in reply to #152689)
100100100
Goodyear stands behind there product. I believe the G614 has a 3 year warranty. They paid for my two when they blew out and prorated the other two.
kigermom
Reg. Aug 2013
Posted 2013-08-20 9:51 PM (#154160 - in reply to #154138)
  Thank you for the information. Another question however. Our local tire company suggested purchasing a Carlisle 750 - 16LT SPORT TRAIL LT. load rating LRE, load capacity 2755, no ply rating. Another is a Carlisle 8 - 14.5LT SPORT TRAIL LT, 12 ply rating, load capacity 2835, a third is Carlisle 700-15LT SPORT TRAIL LT, load rating LRD, load capacity 2040. The last is also a Carlisle ST235/80R16E1 124J B Radial Trail RH. Supposed to be trailer tires.Has anyone heard of Carlisle, good or bad? Would any of the tires I have mentioned (size wise) work? Or do you still recommend Michelin or Goodyear? I haul only 1-2 long trips a year (over 1000 miles) The rest of my travels are within the state. Thanks in advance.
Posted 2013-08-20 10:28 PM (#154162 - in reply to #152689)
Perform a SEARCH on Carlisle tires for the last year. You will find many negative reviews
kigermom
Reg. Aug 2013
Posted 2013-08-25 8:10 PM (#154260 - in reply to #152689)
Thanks gard. I did do some research and as you say there are many negative reports on the Carlisle. I was told by a trailer service man that Carlisles are recommended by dealers  because there is a great markup on them. Looks like Goodyear or Michelin will be the best bet. Thanks again.
