Electric or hydraulic brake?
Last activity 2013-06-14 1:17 AM
2 replies, 3853 views
Bruce Hammerson
Reg. Jun 2013
Posted 2013-06-13 4:32 AM (#152685)
Subject: Electric or hydraulic brake?
I cannot make out the benefit of using electric brakes over hydraulic or air brakes. Could anyone please let me clear my understanding the concept behing the two brake technology?
Edited by Bruce Hammerson 2013-06-13 4:32 AM
hornet
Posted 2013-06-13 9:25 PM (#152725 - in reply to #152685)
Subject: RE: Electric or hydraulic brake?
The research I've done shows you have more stopping power and less heat fade with hydraulic brakes vs electric. All brakes succumb to heat fade but as electric brakes heat up the temperature effects the magnets which is applying the braking force. Also if you were to go with hydraulic disc brakes, they are better at cooling and litigating brake fade because the disc has direct exposure to air.
Posted 2013-06-14 1:17 AM (#152732 - in reply to #152685)
A significant reason why air brakes are preferred in heavier trucks (above 26,000-lbs. GVWR), compared to hydraulic systems, is their robust stopping power when they work - and when they fail. For example, if there's a leak in the brake line of an hydraulic system, fluid pressure can lower to the point where there isn't sufficient force on the brake pads to create the friction needed to slow the wheel. Eventually, if the leak is not repaired, the truck can lose braking power in that portion of the system, reducing the ability to stop in the same distance. With air brakes, the opposite happens. If there is a leak in the air brake lines, the air pressure decreases, which actually activates the brakes at the wheels and brings the vehicle to a safe stop.
