Inflation
Last activity 2013-06-16 5:40 AM
16 replies, 8581 views
Gone
Posted 2013-06-12 8:10 AM (#152643)
Subject: Inflation
10002525
Hubby has a 125 psi air compressor that can not fully inflate our 110 lb trailer tires. I want to buy him a larger one for Father's day. I want to stay under $200. Is it possible, and what would be a good buy?...Thanks
Posted 2013-06-12 8:44 AM (#152648 - in reply to #152643)
Subject: RE: Inflation
Most of the smaller compressors have similar pressure limitations as your present unit, 125 PSI. They feature a single stage compressor, which is a compromise between features and costs. There are a couple of manufacturers that do offer higher pressure units. Here's one in your price range:
http://www.sears.com/craftsman-20-gallon-vertical-air-compressor/p-00916913000P?sid=IDx01192011x000001&kpid=00916913000P&kispla=00916913000P
He's a lucky father.
MrSteve
Reg. Jul 2012
Posted 2013-06-12 3:46 PM (#152663 - in reply to #152643)
If it's a 125psi compressor then sure it can load a tire to 110psi... The pressure regulator needs to be turned up to at least 110psi and not 90psi where it is set to operate air tools, "unless" it has a set regulator that can't be turned up.
Or Dad (he knows about the regulator) is real smart and I just messed up his new dad day gift. ;)
goz63
Reg. Dec 2011
Posted 2013-06-12 4:34 PM (#152667 - in reply to #152643)
There are several out there, Porter Cable for instance, that go to 150PSI. That is what I have and it works great for that. I would also recommend you get one that does not require it to be oiled. If you are using it occasionally that is best. If you use one all the time you won't have a problem with the oiled ones.
goz63
Reg. Dec 2011
Posted 2013-06-12 4:40 PM (#152668 - in reply to #152643)
http://www.homedepot.com/p/Porter-Cable-6-Gal-150-psi-Oil-Free-Panc...
The above one at Home Depot is under $100 and will do what you are looking for. Minimal maint as well.
Gone
Posted 2013-06-12 7:10 PM (#152671 - in reply to #152643)
10002525
Look at this one, even though it is more than I wanted to spend. http://www.lowes.com/pd_155839-70-D55146_4294795216__?productId=103... just looked at the Porter one....hundred bucks? Am I missing something?
Edited by Gone 2013-06-12 7:13 PM
Gone
Posted 2013-06-12 7:15 PM (#152672 - in reply to #152643)
10002525
I think a bigger holding tank would help which the Dewalt does not have. Also, how loud are they?
Edited by Gone 2013-06-12 7:16 PM
Posted 2013-06-12 10:43 PM (#152682 - in reply to #152643)
The larger the tank and the larger the SCFM of the pump, the more valuable the compressor will become. The contractor styled tanks are good for pumping tires or driving nailers. However, they fall on their face when attempting to use any rotary tools like a grinder, impact wrench or spray guns. Once you own a competent compressor, you will find many tools, reasonably priced, that can make your life much easier.
You already have one small compressor. For the modest cost of another, you can purchase one that you won't again out grow, and which can become an infinitely more valuable tool. The first thing to look for is a larger tank, a 15 or 20 gal unit will provide the volume to easily power most tools. The newer compressors can put out higher pressures than many of those available a few years ago. Because most tools are run at under 100 PSI, a higher pressure unit can be easily regulated to furnish any tools' requirements.
Oil less compressors are generally less expensive to purchase than similarly spec ed oil lubricated types. They are noisier, and won't last as many hours under a load. They run hotter as well. But for someone who is a homeowner and not using the unit commercially, they work very well, and have a definite price advantage. Also they generally are lighter and can be easier to move about.
Here's another unit you might consider. It is a high pressure compressor with a larger capacity in the same price range you mentioned;
http://www.lowes.com/pd_340273-43657-HJ300100DI_4294795216__?productId=3341300&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
If you are purchasing a second compressor, I would definitely consider one with a higher capacity pump, and especially one with as large a storage volume as you want to afford. You don't want to out grow the second one as well.
Posted 2013-06-12 11:08 PM (#152683 - in reply to #152643)
I have the Dewalt 200 psi pictured in your link.  I use it on construction sites.
It is a LOT quieter than my PorterCable 135psi Pancake compressor.  I can't speak for running paint sprayers or air grinders. But from the standpoint of being more pleasant to be around. I sure prefer it.
Posted 2013-06-12 11:25 PM (#152684 - in reply to #152643)
When you start operating routinely at over 100 psi...don't skimp on your compressor/tank package...:(
Gone
Posted 2013-06-13 7:28 AM (#152687 - in reply to #152643)
10002525
Ok, I am looking at the Craftsman and the Hausfield. Not sure if the tank size out weighs the PSI. Thinking......
Gone
Posted 2013-06-13 7:56 AM (#152691 - in reply to #152643)
10002525
Craftsman Hausfield150psi 200psi1.5 hp 1.3 hp20 gal 15 gal5.1@40psi 5.5@40psi3.8@90psi 3.8@90psi$199 $219
Edited by Gone 2013-06-13 7:57 AM
Gone
Posted 2013-06-13 8:01 AM (#152693 - in reply to #152643)
10002525
My posts are messed up....ugh
Gone
Posted 2013-06-13 10:23 AM (#152702 - in reply to #152643)
10002525
Lowes was out of the Hausfield so I picked up the Craftsman. I am sure he will like it.
Edited by Gone 2013-06-13 10:26 AM
Gone
Posted 2013-06-15 7:18 PM (#152773 - in reply to #152643)
10002525
He opened it early today and loved it! Thanks for all of the suggestions!
Posted 2013-06-15 10:10 PM (#152777 - in reply to #152773)
Now for all the rest of his special days, you can buy him air tools. His new compressor will do a lot more than just inflate tires.
Gone
Posted 2013-06-16 5:40 AM (#152784 - in reply to #152643)
10002525
Hahaha...he already has a lot of air tools.
Edited by Gone 2013-06-16 5:41 AM
