Putting things on walls
Last activity 2013-06-12 7:54 AM
6 replies, 5680 views
illini
Reg. Mar 2009
Posted 2013-05-26 8:39 PM (#152255)
Subject: Putting things on walls
I would like to hang some things on our walls in our trailer just not quite sure what is the best way to do this with the soft touch walls.  Like to have a way to hang with out doing harm to the walls(soft touch).
Thanks.
terri s
Posted 2013-05-27 9:41 AM (#152270 - in reply to #152255)
Subject: RE: Putting things on walls
500100100100
I would think you could use some of those "commando" hooks that have the 3M removable tape on them. I hang brooms and mops from mine in the laundry room and you just pull on the tab when you are ready to move or remove things. Not expensive and available at Walmarts everywhere.
Candy girl
Reg. Apr 2006
Posted 2013-05-28 2:46 PM (#152293 - in reply to #152255)
I thought the same thing about the Commando hooks.  I used one for a clock and it pulled the "wallpaper" away from the board leaving a bubble behind it.  Ended up having to put a screw in wall.
brushycreekranch
Reg. Jun 2006
Posted 2013-05-28 2:49 PM (#152294 - in reply to #152255)
500100100100100
I use commercial grade Velcro!
Fancy That
Reg. Jan 2012
Posted 2013-05-29 9:40 PM (#152326 - in reply to #152255)
I've also used industrial velcro. Buy it in long strips and cut to please. Sticky back on the outsides. I hung an entire grooming organizer on my old trailer door that way (was afraid to "screw in" anything) I also used the 3M Commando hook, too (but not to hold anything heavy)
randemtam
Reg. Jun 2007
Posted 2013-06-07 4:56 PM (#152540 - in reply to #152255)
10010010010025
If your walls are soft touch you may not be able to use the 3M stuff. It's sticky and the soft touch isn't (unless I'm thinking of the wrong wall stuff!) I use the 3M on my LQ walls and it works great. When you pull it off though, you have to go right with the wall and do it slowly. I haven't had any damage thus far and I have hung a lot of pictures! I like hanging photos of our trips. This is one reason I did not choose the soft touch walls when I ordered my trailer.
Ncatanz
Reg. Jun 2008
Posted 2013-06-12 7:54 AM (#152641 - in reply to #152255)
I have the soft touch walls and the 3m comando strips have worked very well.
