padding/mat for inside walls of straight-load 2H BP
Last activity 2013-05-14 10:23 PM
1 replies, 4246 views
Candy girl
Reg. Apr 2006
Posted 2013-05-14 3:29 PM (#151984)
Subject: padding/mat for inside walls of straight-load 2H BP
Need to replace the padding/mat that was on the inside of the exterior walls of my 2H straight-load BP Keifer Built.   Our horses tend to scramble up the walls and it's all ripped, exposing the steel wall.
What do I use and where do I get it?
Posted 2013-05-14 10:23 PM (#151997 - in reply to #151984)
Subject: RE: padding/mat for inside walls of straight-load 2H BP
From a Keifer dealer you can purchase OEM materials. Some side stall paddings are a lower density than the floor mats, and can tend to rip or be cut more easily than the floor mats. The sidewall padding can be replaced with a high density mat which should provide a longer lasting product.
We had one horse that was a consistent kicker and would damage the sidewall of our stock/combo trailer. I installed a plywood inner liner and floor mats to cover the walls. Even after several more years of continual usage, the walls remained intact and undamaged.
