water pump in LQ leaks
Last activity 2013-05-11 12:18 PM
7 replies, 5650 views
headhunter
Reg. Oct 2004
Posted 2013-05-08 2:53 PM (#151834)
Subject: water pump in LQ leaks
50010010025
I am a little stumped by this, maybe someone else has experienced this. When hooked up to city water my water pump leaks. It does not leak when pulling water off the fresh water tank. Tried a pressure regulator which helps, but the water pump is still leaking. What would cause it to leak with city water and not off the tank? Are there seals/gaskets in/on RV water pumps that can be replaced vs replacing the entire pump?
MrSteve
Reg. Jul 2012
Posted 2013-05-08 4:41 PM (#151835 - in reply to #151834)
Subject: RE: water pump in LQ leaks
City water at 60/70lbs pressure at all times at the pump. When you are pulling from the tank, that is suction, no pressure. Rebuild or replace the pump to end the problem, or if money is tight, get a in line adjustable pressure regulator connected at the main and turn it down as low as it can go.
Edit, yes I see you have a regulator, but I don't know if it's adjustable.
Edited by MrSteve 2013-05-08 4:43 PM
Posted 2013-05-08 11:26 PM (#151843 - in reply to #151834)
It all depends on the location of the leak.  Your pump should have a check valve to hold pressure.  Where is the leak?  before or after the pump.  Where does the city water connect ... Before or after the pump?
headhunter
Reg. Oct 2004
Posted 2013-05-11 10:53 AM (#151903 - in reply to #151834)
50010010025
City water connects before the pump, which I thought was an odd design.
headhunter
Reg. Oct 2004
Posted 2013-05-11 11:26 AM (#151904 - in reply to #151834)
50010010025
I am fortunate to have relatively easy access to the water pump and am just going to replace it. So....any recommendations on a replacement model and where to buy (online)?
hornet
Posted 2013-05-11 11:39 AM (#151905 - in reply to #151903)
Originally written by headhunter on 2013-05-11 10:53 AM
That is odd, I've never seen one plumbed that way. I question if any RV pump should be plumbed with the city connection on the suction line of the pump. That might be your problem, the suction side isn't suppose to see pressure.
hornet
Posted 2013-05-11 11:41 AM (#151906 - in reply to #151904)
Originally written by headhunter on 2013-05-11 11:26 AM
Best prices I've seen for RV stuff is PPL motorhomes. I've bought from them a few times with complete satisfaction.
Posted 2013-05-11 12:18 PM (#151908 - in reply to #151834)
There are many internet sources. Here are a couple:
http://www.rvboatparts.com/category/1647/water-pumps?gclid=CIbNtfrFjrcCFYYw4Aodn3oAag
http://www.easternmarine.com/catalogsearch/advanced/result/?brand%5B%5D=275
