Trailer owners with pull down ramps, can I ask...
Last activity 2013-04-29 9:23 AM
5 replies, 6148 views
MrSteve
Reg. Jul 2012
Posted 2013-04-29 7:55 AM (#151641)
Subject: Trailer owners with pull down ramps, can I ask...
How are your ramps constructed? As in what is inside of them? Being that they are around 1" thick, I am assuming they are a steel frame with either plate steel or ply-wood? I need to build a new slide out ramp for my 6 horse head to head, to replace the very tired aluminum ramp and I'm looking for construction ideas. Thanks.
Posted 2013-04-29 8:39 AM (#151642 - in reply to #151641)
Subject: RE: Trailer owners with pull down ramps, can I ask...
     I think most are steel or aluminum frame, maybe a marine grade plywood core for strength, aluminum or steal outer skin, with a rubberized traction surface. I know EBY is using a ramp made of some poly material now. GORE builds an all aluminum ramp... Need to keep it very strong and as light as possible.
Contact Mr. Jackson Gore, he can tell you how he's been building ramps since 1964... http://www.goretrailers.com/
AZgrulla
Reg. Jan 2009
Posted 2013-04-29 8:55 AM (#151643 - in reply to #151641)
The ramp on my 2003 CM Legacy is steel...it's a half ramp.
Posted 2013-04-29 9:14 AM (#151645 - in reply to #151641)
When we purchased a 2H steel BP trailer, in addition to a restoration, I had to rebuild the ramp. It was constructed of a steel angle iron frame with a steel faced exterior skin. The core and exposed interior face was a piece of plywood, with attached lateral strips that helped with securing footing. The plywood was bolted to the steel frame's perimeter.
The original plywood was an inferior grade, and had become rotted and delaminated. In some spots, only the exterior skin prevented holes from being punching through the laminate. The ramp was dismantled to just the bare frame. A new piece of steel skin was then installed into the frame. The inside face was coated with a primer and oil based paint. I purchased a piece of Baltic Birch plywood, 3/4" thick (18MM) and cut it to fit. It was surfaced on one side with two coats of WEST System epoxy to seal that face and edges. After that dried, the epoxied surface was sanded with 30 grit paper to roughen the surface. Additional epoxy was mixed and thickened with Cab o sil and liberally spread over the Birch's surface. The plywood was then placed into the frame, with the wet epoxy against the exterior skin. Additional thickened epoxy was added around the perimeter seam to seal things into place. Various weights were added to hold the plywood against the steel until the epoxy set and cured.
The interior ramp surface was then expoxied as well. It was subsequently painted and oak strips were installed to help with traction. The Baltic Birch plywood is far superior to common lumber yard variants. The 18 MM BB grade has 13 plies of construction, many more than the typical sheathing or cabinet plywood grades most yards sell. There are no interior voids and the surfaces are fully finished. It is very rigid and strong. It is NOT water proof and is made for interior applications. By epoxy coating and encapsulating all its surfaces, it is made water proof.
Today there are many more choices of non skid materials, many of which can be used to improve the surface's traction. Various coatings and rubber/plastic materials can be added. A bed liner material with sand added before it has dried, works well on aluminum running boards; it should be as effective when added to an epoxy finish.
The finished ramp was much stronger and stiffer than the original. We saw the trailer at a show about ten years after we sold it, and the ramp was badly scuffed but fully intact and showing no structural problems. Many of the oak traction strips had been broken and not replaced. The trailer was always stored outside and apparently had little or no preventative up keep after the sale.
This type of construction could also be used in the reconstruction of aluminum doors or ramps, where direct contact of treated materials cannot be used against aluminum.
MrSteve
Reg. Jul 2012
Posted 2013-04-29 9:17 AM (#151646 - in reply to #151641)
Thanks for the replies so far. I will check the link.
My thoughts was this. Being this is a slide out ramp from under the trailer... I was thinking on building the ramp out if 3/16 angle iron for the frame, then add 14ga plate steel for the top and bottom surface with "2" sheets of marine grade 1/4 ply-wood (1 sheet grain up/down, other with grain left/right), then for added ease of roll out, adding 2" wheels on all 4 sides, with pins to secure for storage and loading and if course a rubber mat on top. Dose this sound like it would work?
Edit... I'm reading your post now, you replied while I was working on my post.
Edited by MrSteve 2013-04-29 9:19 AM
MrSteve
Reg. Jul 2012
Posted 2013-04-29 9:23 AM (#151648 - in reply to #151641)
Thank you Gard, that is very informative, that post gives me lots to work on.
