What kind of trailer can an LR4 pull?
Last activity 2013-04-15 11:05 AM
3 replies, 6108 views
SofiPony
Reg. Apr 2013
Posted 2013-04-13 9:22 PM (#151287)
Subject: What kind of trailer can an LR4 pull?
I'm new to this- and I'm rather confused abou the whole process. Can an LR4 pull a two horse trailer with a dressing room? Is that at all possible? I honestly don't have the slightest clue. Thanks for helpng!
Posted 2013-04-13 11:19 PM (#151288 - in reply to #151287)
Subject: RE: What kind of trailer can an LR4 pull?
http://carleasingmadesimple.com/business-car-leasing/land-rover/discovery/towing-capacity/
750 kg = 1650 lbs
Posted 2013-04-14 4:53 AM (#151289 - in reply to #151287)
From the 2013 LR4 website....
http://www.landrover.com/us/en/lr/lr4/explore/lr4/
5.0 V8 Auto
Weights lbs
Weight from*5,623
Gross vehicle weight*7,143
Towing
Maximum towing**7,716
Unbraked trailer1,653
Maximum trailer nose weight551
Maximum mass of vehicle and trailer combination air suspension (GTW)14,859
Carrying lbs
Maximum roof load (including roof rails/bars)165
Maximum payload (including driver 75kg)1,484
Performance
Maximum speed (mph)121
Acceleration (secs)
0-60mph7.5
Fuel economy
Combined C02emissions (g/km)328
Useable fuel tank capacity (gallons)18.9
*Including fluids, 90% fuel and 165.3lb driver
**If towing for commercial gain, please refer to your Land Rover Dealer for information relating to digital tachograph installation
adeberti
Reg. May 2007
Posted 2013-04-15 11:05 AM (#151320 - in reply to #151287)
The LR4can pull a 2H BP trailer (especially if Aluminum) ,but here is what i would make sure:-you have a towing package or at least a transmission cooler installed-you use a weight distribution set up-make sure the trailer is not tongue heavyA good trailer dealer will be able to help you with the last two, while the first could be done at the dealership or other qualified shops.This site mostly deals with trucks, so i would probably suggest going to a LR forum and ask questions there. After you get a good idea on the LR4 capabilities (which should be okay,a s they used in Europe as well) you'll get a ton of help here for trailer
