Freightliner Sportchassis Question
Last activity 2013-04-07 2:23 PM
3 replies, 4968 views
bechack
Reg. Mar 2006
Posted 2013-04-06 8:37 PM (#151125)
Subject: Freightliner Sportchassis Question
Looked at one today with only 80K on it.  Question is, there are two fuel filler caps, right and left.  Do they go to the same tank?  I could not find a switch for R/L fuel tanks.
Thanks in advance.
gonzo1066
Reg. Oct 2010
Posted 2013-04-06 10:04 PM (#151127 - in reply to #151125)
Subject: RE: Freightliner Sportchassis Question
Typically both tanks are connected together.   You can pull into a big truck fuel station and fill them seperatly from both sides of the truck.
cajunmuleman
Reg. Oct 2011
Posted 2013-04-07 8:52 AM (#151132 - in reply to #151125)
The fuel level will equalize in both tanks. If one is empty and you fill one tank they will both end up 1/2 full as the two tanks are connected. This helps equalize the weight on both sides of the truck also.
MrSteve
Reg. Jul 2012
Posted 2013-04-07 2:23 PM (#151146 - in reply to #151125)
As above, but takes a bit of time for the tanks to equal out, in other words if you are at a 1/4 tank and only fill one side and drive away, then soon after you will only read around 3/4 full. Point, fill up, wait a a minute or 2 at the pump then top it off again.
