Need hitch advise
Last activity 2013-03-28 12:21 PM
5 replies, 4519 views
Mibound
Reg. Mar 2013
Posted 2013-03-26 1:11 PM (#150868)
Subject: Need hitch advise
We are moving from CA back to MI shortly. We have a '91 F250 460ci, with a '92 3 horse slant Logan trailer. Have a 9ft slide in camper on the back. We are taking our 1200 lb. guy home with us- only one in the trailer. We have gotten by with a Reese Class 3 for years, but with the camper and needed extension, I'm getting conflicting suggestions - from the 3 will be fine, to a welded IV or a bolted on V so I can take advantage of a 2 1/2 extension, as opposed to the 2". What has worked for you ? Thanks
goz63
Reg. Dec 2011
Posted 2013-03-26 5:03 PM (#150873 - in reply to #150868)
Subject: RE: Need hitch advise
What is the weight of your trailer and also the weight of your camper? A class three hitch is usually good up to 5K pounds where as a class IV is good up to 12K. The class three tongue max of 500 lbs and class IV 1200 would drive my decision along with the GVWR of trailer. Depending on the weight of your trailer and the camper, you may be maxed out coming through the mountains. Make sure the tires are in good shape and are aired up.
Ike
Reg. Jun 2005
Posted 2013-03-26 5:15 PM (#150874 - in reply to #150868)
I had a 90 F250 with that 460 hauling a lil 18'travel trailer. Never regretted getting the bolt on Class V.
That 460 gonna drink sum gas I bet.  Be safe.
Saddleup
Reg. Apr 2012
Posted 2013-03-26 5:57 PM (#150875 - in reply to #150868)
Since you are using a hitch extension, I would definitely go the class 1V hitch. When you extend that puts a lot  of pressure on the hitch. I would assume that you Logan has a considerable amt of hitch weight. Have a good safe trip..
trot-on
Reg. Dec 2009
Posted 2013-03-26 11:24 PM (#150882 - in reply to #150868)
we had 9.5' camper for years, and 4 horse trailer. Our extension bar was solid bar stock, not tubular. Had a tubular one early on that bent.
Mibound
Reg. Mar 2013
Posted 2013-03-28 12:21 PM (#150920 - in reply to #150868)
Thanks for all the input, ended up ordering a Class V with 2 1/2" extension.
